Domain & Range of 2x^2 + 4x - 3
The discussion revolves around finding the domain and range of the quadratic function 2x^2 + 4x - 3. Participants are exploring the implications of different approaches to solving the problem, particularly focusing on the method of completing the square.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss various methods for determining the domain and range, including equating the function to zero and completing the square. Questions arise regarding the validity of these methods and the assumptions made during the process.
There is an ongoing exploration of different methods to approach the problem. Some participants express confusion about the initial attempts and the reasoning behind them, while others provide clarifications on the correct interpretation of the function. Guidance is offered regarding the use of derivatives and the method of completing the square.
Participants question the assumptions made about the function and whether there are specific conditions on x and/or f(x). There is also mention of potential confusion arising from not clearly defining the function as f(x).
kuahji
Find the domain & range of the function.
2x^2 + 4x - 3
I attempted to solved doing the following
2x^2 + 4x = 3
x^2 + 2x = 3/2 (divided by two)
(x+1)^2 = 5/2 (completed the square & added one to both sides)
(x+1)^2 - 5/2 = 0
So I put the range was (-5/2, infinity), but the book has it (-5, infinity). It seems any problem where the leading coefficient is greater than one, I'm getting incorrect answers. So there must be an error in how I'm trying to solve the problem.
I don't understand why you have equated the function to zero. As it stands, the range and domain is the real line, assuming x and f(x) are real. Are there any conditions on x and/or f?
Figured out the way to do it, sorry.
2x^2 + 4x -3
2x^2 + 4x = 3
2(x^2 + 2x) = 3
2(x+1)^2 = 5
2(x+1)^2 - 5
Even though now I'm kinda curious as to why the first method I tried was incorrect. Like why can't you just divide the whole thing by two.
Well the first time you tried you Assumed that it was equal to zero. And because of that, you changed it to another polynomial, where the co efficients are divided by 2. It has the same ZERO's but different values for other things. The second time you tried you didn't assume anything, you just wrote the expression in another completely equivalent way.
As Gib Z suggested, "2x^2 + 4x - 3" means nothing. Write "f(x) = 2x^2 + 4x - 3" to avoid primary confusion.
Thanks, this explanation helps. :approve:
Well i think it makes sense equating the derivative to zero so that you can find out wether there is a maxima or minima.
After finding the value of x for which there is a maxima or minima then you will have to find the value of the maxima or minima.
Derivatives should not even be considered when determining the domain and range of a real-valued quadratic function. There exists quite an easy way to express [tex]f(x) = ax^2 + bx + c, a \not=\ 0[/tex] in the form [tex]f(x) = a(x - h)^2 + k[/tex]. If a is negative, then k is the maximum value of the function, and if it is positive, then k represents the minimum value of the function. The "completing the square" method really is much quicker.
  • · Replies 23 ·
