How Is Air Pressure Calculated at the Center of a Hurricane?
The discussion revolves around estimating the air pressure at the center of a hurricane, specifically with a wind speed of 300 km/h. Participants are exploring the relationship between static and dynamic pressure, as well as the calculations involved in determining the total pressure in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the conversion of wind speed from km/h to m/s and the implications of unit accuracy on the calculations. There is a focus on the relationship between static pressure, dynamic pressure, and total pressure, with some questioning the phrasing of the original problem. Others explore how to estimate static pressure given the context of the hurricane.
The discussion is ongoing, with participants providing insights and corrections regarding unit conversions and the relationships between different types of pressure. Some participants have suggested assumptions to simplify the problem, while others are still grappling with the implications of these assumptions.
There is uncertainty regarding the phrasing of the original problem, which may affect the interpretation of the calculations. Participants are also navigating the challenge of estimating values that are not explicitly provided in the problem statement.
physicsnewby
Estimate the air pressure at the center of a hurricane with wind speed of 300 km/h at the center. Answer in Pa
P + 1/2 (density)(velocity)^2
density of air 1.29 kg/m^3
P + 0.5 (1.29 kg/m^3)(90000)
Pressure = 58050 atm
1 atm = 101.3kPa so 58050 atm x 101.3 kPa = 5880465 kPa or 5.88 x 10^9 Pa
but the answer is 9.7 x 10^4
What am I doing wrong?
don't use km/h, convert to m/s, if i may hazard a guess
P= .5*(1.29 kg m^(-3)) (83.33333 ms^(-1))^2
= .5 *(1.29 kg m^(-3)) (6944.444444 m^2 *s^(-2))
= 4479.167 kg m^(-1) s^(-2)
= 4479.167 Pa
= 4.48 E3 Pa
if the equation was right, the answer was probably wrong, or i am, probably =).
What you are doing wrong is being sloppy with units and not stopping when you get a ridiculous answer. 58,050 atm? When you get an answer like that it means you have done something wrong.
You also have a sign error. What is the relation between static pressure, dynamic pressure, and total pressure? Which of these pressures is the question asking you to give?
Edited to add:
Is this truly how the question is phrased? If so, it is wrong. Much better question: Estimate the pressure at the calm center of a hurricane with winds of 300 km/h just around the center.
I copied and pasted the question directly onto the post, so this is what we have to work with.
I know I did something wrong with the units, but even when they are changed I still get nowhere near the right answer.
Look at bel's post. The dynamic pressure is 4.48 kPa.
To answer your question about total pressure and relation of static/dynamic, isn't P = P + 1/2 density(velocity)^2 the relationship?
To label it I think it's P(total) = P(static) + (dynamic)1/2 density(velocity)^2So, I guess what I've been calculating is the dynamic. How do I calculate static?
You already stated it:
[tex]P_{total} = P_{static} + P_{dynamic}[/tex]
where
[tex]P_{dynamic} = \frac 1 2 \rho u^2[/tex]
Now assume the static pressure is constant over the eye of the hurricane and that the total pressure does not exceed one atmosphere. What is the pressure total pressure at the dead center of the hurricane?
I'm not sure ... I'm confused
If P static is constant, wouldn't that mean its 0 ?
To me, that would then mean Ptotal = P dynamic, which isn't the case
Why would think that? Constant means unchanging, not zero. In other words, assume [itex]P_{static}[/tex] has the same value at the center of the hurricane (no winds) as it does at the eye wall (max winds).[/itex]
So, if its unchanging and there is no formula for it, how do we calculate for it if its not a given?
Do something else that helps solve the problem. A big part of physics is knowing how to estimate things. For example, assume the pressure at the total pressure at the eye wall is one atmosphere.
Not sure if this makes sense...but, if I assume that the total pressure is 1 atm or 101.3 kPa, and Pstatic is 100kPa, and the calculated dynamic is 4.48 kPa, maybe I should do something like this: (although, I'm not accounting for total pressure ?!)
P1 + 1/2dv^2 = P2 + 1/2dv^2
100kPa +4.48kPa = 100kPa +P2dynamic
From your last post,
[tex]P_{dynamic} = \frac 1 2 \rho u^2 = 4.48 \text{kPa}[/tex]
From post #11,
[tex]P_{total} = 1 \text{atm}[/tex]
From post #7,
so what is the static pressure? Assuming that the static pressure inside the eye wall is constant, what is the total pressure at the center (where the wind speed is zero?)
If 1 atm = 101.3 kPa
Then, I'd think static pressure is:
101.3 = Pstatic + 4.48 kPA
Pstatic = 96.8 kPa in Pa 9.7x10^4
:smile:
  • · Replies 23 ·
  • · Replies 17 ·
