Questions about principle of moments
  • Thread starter Thread starter crpcrpcrp
    Moments Principle
The principle of moments states that for a system in equilibrium, the sum of clockwise moments equals the sum of anticlockwise moments. In the provided problem, the total clockwise moment about pivot B is calculated as 1800 Nm from a 600 N weight at a distance of 3 m. The total anticlockwise moment is expressed as 6RC Nm, where RC is the normal reaction force from the cradle. To determine the mass of the counterweight needed when the applied force (FA) is 25 N, one must analyze the conditions under which RC becomes zero, indicating the boom is about to lift.
  • Understanding of the principle of moments in physics
  • Knowledge of equilibrium conditions in mechanics
  • Familiarity with calculating moments using force and lever arm length
  • Basic algebra for solving equations involving forces and moments
  • Study the concept of equilibrium in static systems
  • Learn how to calculate moments using the formula M = F × d
  • Explore the application of the principle of moments in real-world engineering problems
  • Investigate the relationship between forces and distances in lever systems
Students preparing for physics exams, educators teaching mechanics, and anyone interested in understanding the application of the principle of moments in engineering and physics.
crpcrpcrp
Hi
I have a physics exam tmorrow and I was hoping I could get a little help with the moments problem. I attached the drawing and the question asks:
a-1. State the principle of moments
b-1.Write down expressions including W, Rc and FA for
(i)the total counter clockwise moments about pivot B
(ii)the total clockwise moments about pivot B
(iii)what is the value of Rc when the first boom loses contact with its cradle
2.Use the results in 1. (i),(ii) and (iii) above to find the mass of the counterweight that must be used if FA=25N is just enough to start raising the boom (g=10ms-2)
a-1 the principle of moments states that for a system in equilirium the sum of the clockwise moments is equal to the sum of the anitclockwis moments
b-1(i)600N X 6m=3600Nm
And we were never atught how to answer the rest so from there I'm lost.Help please
But what is a moment defined as, in terms of a force and a lever arm length?
Starting with the sum of the moments being zero in equilibrium is good, but then you need to use that to help you calculate the forces that are spaced at different distances from the pivot...
In this problems the moments are easy to calculate since the moment arms are just the horizontal distances to the line of action of the involved forces.
For instance for the weight of the arm of the boom, 600 N, which rotates clockwise about point B the moment will be
[tex]600 \times 3 = 1800 \ Nm[/tex]
clockwise since the moment arm for this force is three meters.
The normal reaction force from the cradle,[tex]R_C[/tex], rotates the boom anticlockwise about the point B so its moment will be
[tex]R_C \times 6 = 6R_C \ Nm[/tex]
anticlockwise about B.
To answer part (iii) you need to consider what happens as the applied force, [tex]F_A[/tex], is increased. What will happen is as the applied force is increased the reaction force of the cradle will decrease while the boom is still in equilibrium. When the reaction force becomes zero the boom is at the point of lifting up, but the clockwise anticlockwise moments will still balance out at this point. Only when the applied force is increased even further will the boom begin to lift.
  • · Replies 105 ·
  • · Replies 50 ·
