Low Voltage BJT: Why 0.225V - 75mV?
The discussion centers on the output voltage range of a BJT (Bipolar Junction Transistor) biased between 0 and 5 volts on the base, with a drain voltage of 5 volts. The voltage drop across the collector and emitter, known as V_CE_SAT, typically measures around 0.35 volts when the BJT is fully saturated. The user inquires about the significance of the voltage values 0.225V and 75mV, concluding that 0.075V is lower than 0.225V, which may represent V_CE_SAT.
  • Understanding of BJT operation and terminology (emitter, base, collector)
  • Knowledge of NPN and PNP transistor types
  • Familiarity with voltage drop concepts in electronic circuits
  • Basic principles of transistor saturation and conductance
  • Research the characteristics of NPN and PNP transistors
  • Learn about V_CE_SAT and its implications in circuit design
  • Explore the effects of base current on BJT conductance
  • Study the role of resistors and diodes in BJT logic circuits
Electronics students, circuit designers, and engineers working with BJTs in logic circuits and saturation analysis.
a.y
i want to know why at some point the low output voltage for a bjt biased between 0 and 5
on the base
and voltage 5 at the drain
ranges between 0.225v and 75mv so which of them is the low voltage pz answer me now i have a project to deliver
BJT? BASE? DRAIN?
A BJT has three terminals, EMITTER, BASE, COLLECTOR,
There are two varieties of BJT:
NPN and PNP which represent differeing doping polarity used in making the devices sections.
A BJT transistor driven into fully saturated conduction
will usually have a relatively small voltage drop between
its COLLECTOR and EMITTER; the value of that voltage
is called "V_CE_SAT" for "saturated Voltage between
COLLECTOR and EMITTER" and it is often around
0.35 Volts.
When there is little BASE current the transistor will present
a very low conductance (i.e. a high resistance) between
COLLECTOR and EMITTER, and thus the voltage drop
across the COLLECTOR and EMITTER will be large, almost
as large as if the transistor was taken out of the circuit
and a large -- e.g. 50 million ohm -- resistor is placed
between where the collector and emitter terminals were.
And usually one doesn't speak of "low" voltage with
a single BJT since usually a logic circuit involves
at least one BJT and one diode and at least some
resistors or other BJT components.
However comparing magnitudes, 0.075V is LOWER than
0.225V; I suspect 0.225 could be V_CE_SAT, I have
no idea what 0.075V represents...
11K
  • · Replies 21 ·
  • · Replies 22 ·
