What causes water to oscillate at high temperatures in the Leidenfrost effect?
  • Context: Graduate
  • Thread starter Thread starter Tamerlane
The discussion revolves around the Leidenfrost effect, specifically focusing on the oscillation of water droplets at high temperatures, particularly around 410 Celsius. Participants explore the mechanisms behind the oscillation, the role of surface tension, and the behavior of water molecules within the droplet.
  • One participant describes the Leidenfrost effect as the phenomenon where a water droplet does not boil upon contact with a surface above a critical temperature, creating a vapor layer.
  • Another participant mentions that surface tension, attributed to dipole-dipole attraction among water molecules, may explain the oscillation observed in the droplets.
  • A participant questions whether dipole-dipole attraction is sufficient to create transverse waves, noting the observation of multiple modes of oscillation in their experiments.
  • Another suggests that the phenomenon might be related to "vortex shedding" from a bluff body, introducing a different perspective on the observed behavior.
Participants express differing views on the mechanisms behind the oscillation of water droplets, with some attributing it to surface tension and others suggesting vortex shedding. No consensus is reached on the exact cause or the nature of the oscillations.
Participants mention various factors such as temperature, surface characteristics, and the physical state of water, but these aspects remain unresolved and depend on further investigation.
Tamerlane
First of all, let me say that I'm a french [in the way that i speak french] student and most probably my sentences will not be as accurate as they should, excuse me in advance.
To make a long story short, the Leidenfrost effect makes a water drop to stop "boiling" at temperatures higher than 240 Celsius. The principle is as follows: the suddent heating of the water (when it falls on the surface) immediately creates a vapor layer between the liquified water and the surface.
Note: we have roughly measured the actual temperature of the water at around 80 celsius.
The same effect happens with a particular plastic surface that as been "polished" (or scratched) with an extremely thin sandpaper OR a surface covered with teflon => there is small "bubbles" of air that gets trapped between the real surface and the water.
Anyway, what interests me and my group is that when you heat the water ; our optimal temperature (for the oscillating mode we concentrated on) is about 410 celsius, at that point and from a very particular volume of water [the drop constantly evaporate], it starts oscillating at a frequency of about 10Hz and increasing. At that point, the drop has a rounded triangular shape, but it's so fast, you see 6 and arguably 8 tip to the "star" it forms.
Now, i'd like to know if anybody has ever heard of or work on such thing, we'd especially like to know what exactly happens, what makes the water turn on itself or oscillate [we're not even sure about the movement of the molecules within the drop]. If there is any formula that exists to describe such phenomenon or anything else.
Also, we are being told it has something to do with surface tension, anyone can help?
Thank you
Science news on Phys.org
Suface tension created by the dipole-dipole attraction of water molecules are the reason for this. however, you may want to try a chemistry forum for the answer.
Is this the definition?
LEIDENFROST EFFECT - Where a liquid will not wet a surface and becomes insulated from the surface by a layer of vapor if the surface is above a critical temperature of the liquid. The surface is usually well above the liquids boiling point. Water beads seems to last forever in a 400 F frying pan on a stove, where they would boil away in 5 seconds if the pan were only 220 F. McGraw Hill, Dic. of Sci. and Tech. Terms, 5th ed, 1994 (200,000 definitions in one book)
Thought posting the definition I use in my book "Effects and Their Uses" should be included here.
Steve Stillman
Steve: well...i already know that, I've been looking at those water beads for hours, but thanks anyway
2Pac: hmm...dipole-dipole attraction, that might be the answer...but do you think that would be enough to create a cross wave [now I'm really not sure if it's the right word, in french it's called "onde transversale" where onde = wave] and we observed 6 different modes of oscillation, we are currently studying the 4th mode because it's the one that we have the most facility to recreate
You are more likely looking at "vortex shedding" from a "bluff body" --- sorry, no French translation for you.
hmm, that sounds interesting, i'll look for that :)
  • · Replies 19 ·
  • · Replies 152 ·
12K
