Thread Closed
Rotating Bicycle Wheel
Share Thread Thread Tools
Jun26-07, 11:51 PM   #1
A professor holds a bicycle wheel rotating at 402 rev/min by a string attached to a weightless axle 20 cm from the wheel. The acceleration of gravity is 9.8 m/s^2. If all 7.5 kg of the wheel can be considered to be at its 53.6 cm radius, at what frequency in rpm does it precess?
2. Relevant equations
3. The attempt at a solution
Frequency=omega
I honestly am stumped with this problem but I was thinking of using a rotational kinematics equation to solve this.
The 402 rev/min can be converted to Omega initial. We can solved for Omega final using wf^2=wi^2 +2a(delta x).
Please help if you can!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jun27-07, 06:18 AM   #2
Admin
Perhaps this will help.
http://hyperphysics.phy-astr.gsu.edu/hbase/rotv2.html
If all 7.5 kg (the mass) of the wheel can be considered to be at its 53.6 cm radius, . . .
What is the moment of inertia I for a ring/hoop.
http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html#cmi
see also http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
Jun27-07, 07:11 PM   #3
Ok here's what I did.
(Mass of the wheel) * (Radius of the wheel)^2 (Omega given) - (Mass of the wheel)* (Length of the string)^2 * (Omega Unknown) = 0
(7.5 kg)(.536 m)^2(402 rev/min) - (7.5 kg) *(0.20 m)^2 * (Omega unknown) = 0
Is this the right to solve this problem? I feel as if I'm not getting/missing something.
Thread Closed
Thread Tools
Similar Threads for: Rotating Bicycle Wheel
Thread Forum Replies
variable diameter bicycle wheel Classical Physics 3
Gyroscope/bicycle wheel question Classical Physics 7
spinning bicycle wheel Introductory Physics Homework 1
Rotating Wheel Problem Introductory Physics Homework 1
rotating wheel question Introductory Physics Homework 4
