Conservation of momentum and wood ball problem
The discussion centers on calculating the maximum speed of a 0.900 kg projectile that can hit and embed itself in a 20.0 kg wood ball suspended by a 1.50 m wire without breaking the wire, which has a maximum tension of 300 N. The user attempted to apply the tension formula (T = mv²/r) and the conservation of momentum but encountered errors in their calculations. The correct approach requires incorporating gravitational forces into the net force analysis, as the tension must counteract both the gravitational force and the centripetal force when the projectile impacts the wood ball.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of tension and centripetal force
  • Knowledge of conservation of momentum principles
  • Ability to perform calculations involving square roots and algebraic manipulation
  • Review the derivation of the tension formula in the context of circular motion
  • Study free-body diagrams to visualize forces acting on suspended objects
  • Learn about energy conservation in inelastic collisions
  • Explore examples of similar problems involving tension and momentum
Physics students, educators, and anyone interested in mechanics, particularly those studying dynamics and collision problems.
Amria
Problem:
A 20.0 kg wood ball hangs from a 1.50 m-long wire. The maximum tension the wire can withstand without breaking is 300 N. A 0.900 kg projectile traveling horizontally hits and embeds itself in the wood ball.
What is the largest speed this projectile can have without causing the cable to break?
What I have tried:
I tried to use the tension formula (T = mv^2/r) along with the conservation of momentum formula.
First I tried:
v = sqrt(Tr/m) = sqrt(300*1.5/20) = 4.74
and then m1v1 = m2v2 = mfvf
so .9v = 20.9 *4.74 = 110.2 m/s which was wrong
then I tried:
v = sqrt(Tr/m) = sqrt(300*1.5/20.9) = 4.64
so .9v = 20.9 * 4.64 = 107.8, which is also wrong
Can anyone point out where I'm making a mistake? I think the theory is sound, but I can't figure out where I'm going wrong.
The NET force is F=(mv^2)/r. The two forces acting on the hanging mass(es) are gravity and the tension in the wire. I cannot see that you've accounted for the former. Go back, draw a free-body diagram with the gravitational force included, and see where your thought leads you.
Amria said:
Problem:
What I have tried:
First I tried:
then I tried:
  • · Replies 19 ·
  • · Replies 33 ·
