Finding the Height of a Two-Dimensional Completely Inelastic Collision
The problem involves a completely inelastic collision between two identical balls of putty, where one ball is released from a height and collides with the other ball that is at rest. The objective is to determine how high the combined mass of the two balls will rise after the collision.
  • The original poster attempts to clarify whether they have all necessary information and expresses uncertainty about the formulas involving the angle theta. Some participants suggest calculating the velocity of the first ball before the collision using energy conservation principles, while others mention using momentum conservation for the combined mass after the collision.
Participants are exploring various steps to approach the problem, including energy conservation and momentum conservation. Some guidance has been provided regarding the calculations needed, but there is no explicit consensus on the method or the completeness of the information available.
The discussion includes a mention of the assumption that the motion of the balls is roughly horizontal just before and after the collision, which may influence the calculations. There is also a note about the original poster's deadline for the homework submission.
PhysicsPhun
Two identical balls made of putty, each of mass 1.50 kg, are suspended from strings of length 28.0 cm so that they touch when in their equilibrium position. We pull one of the balls back until its string makes an angle theta = 73.0 degrees with the vertical and let it go. It collides totally inelastically with the other ball, which means the two balls remain stuck together after the collision. How high will the stuck-together balls rise above the bottom most point?
So this is a Completely Inelastic Collision in Two deminsions, right?
Do i have all the information I need or do i have to find velocities, I don't know any formulas with theta involved.
While it is in 2-dimensions, the problem only has one degree of freedom (θ). Try completing the following steps to solve the problem:
- Copmpute the velocity of the first ball immediately prior to its collision with the second ball. Do this by considering the conversion of the potential energy the ball has at its original height into purely kinetic energy (ignore friction/air resistance).
- Compute the velocity of the two balls together immediately after the collision. This is simply a 1D momentum conservation equation (this involves the assumption that the motion of the balls just before and just after the collision are roughly horizontal; this assumption is supported by the description of the equilibrium position of each ball).
- Compute the height of the balls based on their initial velocity (the velocity right after the collision). (Use the simple geometry of the situation to find the correspondence between the angle of the string and the height of the ball). This is found using the same calculation as step 1; i.e., use the conservation of energy.
1. calculate the potential energy of the raised ball
2. calculate the kinetic energy it will have at the bottom
3. calculate the velocity of the 2 balls stuck together (momentum conserved, not energy)
4. calculate the kinetic energy of the 2 balls
5. calculate the height where the potential energy equals the kinetic energy you found in part 4
missed deadline by 2 mins hehe ohwell, thanks for the tips.
Next time post your questions a bit earlier so they may be answered in time.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 33 ·
