Conservation of Energy roller coaster car
The problem involves a roller coaster car that descends and then ascends a hill, with a focus on the forces acting on a passenger at the top of the hill and the radius of curvature of the hill. The context includes concepts from mechanics, specifically conservation of energy and forces.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of conservation of energy to find the velocity at the top of the hill and the subsequent calculation of the radius of curvature. There are questions about the validity of kinematic equations under varying acceleration and the relationship between normal force and gravitational force.
Some participants have attempted to apply conservation of energy and have calculated velocities, but discrepancies in the expected radius of curvature remain. There is ongoing exploration of the forces acting on the passenger and how they relate to the net force and radius of curvature.
Participants are grappling with the correct interpretation of forces at the top of the hill, particularly how to account for normal and gravitational forces in determining net force and radius of curvature. There is a noted difference between calculated results and expected answers, prompting further inquiry.
kiwikahuna
A roller coaster car starts from rest and descends 40 m before rising 20 m to the top of a hill. The passenger of mass 75 kg at the top of the hill feels a normal force of 368 N. The radius of curvature of the hill is...?
F = m * a
a = v^2/r
Because we are given the force and the mass the person, I found the acceleration and set acceleration = v^2/r. Velocity isn't given so I used the kinematics equation: Vf^2 = Vi^2 + 2a(distance)
where Vi =0 and distance = 60. Once I found the velocity I went back and plugged that number into a =v^2/ r to find the radius but I'm not getting the right answer at all. Any help would be great.
The title of your post is "conservation of energy." It doesn't appear that you've applied this concept to your attempt at the solution.
I suggest you find the velocity at the top of the hill by simply considering the change in gravitational potential energy associated with the roller coaster's descent and subsequent ascent.
Please also note the kinematics equation you provided cannot be used because that equation is only valid under constant acceleration.
Thank you for the suggestions.
I used the conservation of energy formula:
mg(h1) = 1/2 mv^2 + mg(h2)
where h1 = 40 m and h2 =20 m
I find the velocity to be 19.8 m/s at the top of the 20 m hill.
I plugged the velocity back into a = v^2/r and I get r to be 80 m but it's still not the right answer (which is actually 30m )
Draw a free-body diagram of the car, noting that it as at the TOP of the hill. Also note that the net force must be equal to the quantity (mv^2)/r. How do the normal force and force due to gravity relate? What does this say about the radius of curvature?
there's a gravitational force down (with the mass of both the cart and the person)
There's a normal force going up. But this is the normal force that the person feels. To find the net force, you would have to add these two forces together? Any more explanation on this topic would be very helpful. Conceptually I don't understand why you would have to add these two forces together as opposed to subtracting them.
The normal force and the gravitational force act in opposite directions. Thus, you would in fact subtract them to find the net force. The force due to gravity is stronger than the normal force, so the net force points towards the center of curvature, as it should. However, I am getting 80 m for my answer, just like you. I cannot figure out why 30 m is recorded as the correct answer.
I've done countless problems like this in the past, so I do not know where I'm going wrong.
It'd be great if anyone else could chime in.
  • · Replies 16 ·
