Calculate the angle between the total acceleration
  • Thread starter Thread starter Momentum09
    Acceleration Angle
The problem involves a ball swinging in a vertical arc, where the objective is to calculate the angle between the total acceleration and the string when the ball is at a specific angle to the vertical. The context includes concepts of tangential and radial acceleration influenced by gravity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using vector analysis to find the total acceleration and its relationship to the string. There are attempts to calculate the total acceleration and confusion regarding the radial acceleration and its implications.
The discussion is ongoing with participants exploring different aspects of the problem. Some guidance has been offered regarding the use of vectors and dot products, while others express confusion about the role of radial acceleration and the forces acting on the ball.
Participants question the assumptions regarding the radial forces and the conditions under which the ball moves, particularly in relation to the tension in the string and the gravitational forces. There is a recognition that the analysis may vary depending on the ball's velocity during its swing.
Momentum09
A ball tied to the end of a string swings in a vertical arc under the influence of gravity. When the ball is at an angle of 23.5 degrees to the vertical, it has a tangential acceleration of magnitude gsin(theta). Calculate the angle between the total acceleration a and the string at theta 23.5.
I first solved for the total acceleration using a = square root of [A(radial)^2 + A (tangential)^2]
But then I don't know what to do next. Can someone please give me some hints? Thanks!
If you use vectors to find the total acceleration and take the dot product with a vector representing the string, then you should get your angle.
Sorry I don't quite understand. I did total acceleration x cos 90, but it wasn't correct.
[Don't pay any attention to this non-sense! I posted further down what I'm overlooking here. - jackiefrost -]
Does the ball ever move radially? Does it ever move closer or further away from the pivot point? What does that then say about the radial acceleration? How about the total acceleration?
the total accelaration is vector sum of the radial and atngential accelaration so when u have their dot product(as chaoseverlasting said) with the radial accelaration divide the entire thing with the magnitude of radial and total accelartion u get ur ans
I don't understand something here? The radial acceleration must be the sum of all radial forces. The only radial forces are the tension in the string, T, and the gravitational component in the radial direction, mg*cos(theta). But, assuming the string is inelastic, wouldn't the tension T be exactly canceled by mg*cos(theta) and the sum of radial forces be zero? If so, how can there be any radial acceleration?
But, as I've sat here thinking about this, I guess what I stated above is only true when the velocity of the ball is zero (at extremes of swing or when initially released). Hmmm... I think I forgot about the v^2/L aspect when it's swinging :eek:.
  • · Replies 26 ·
  • · Replies 23 ·
  • · Replies 38 ·
