Surface Water Freezing: Can It Happen?
Surface water can freeze even when the air temperature is above 0 degrees Celsius due to the influence of ground temperature and heat flow dynamics. The discussion highlights that structures like bridges can freeze before roadways because they are typically colder than the surrounding air. In prolonged cold conditions, the ground temperature can drop below freezing, allowing moisture on the surface to freeze despite warmer air temperatures. Understanding heat sinks and sources is crucial in this phenomenon.
  • Basic understanding of thermodynamics and heat transfer principles
  • Knowledge of environmental factors affecting temperature, such as ground and air temperature
  • Familiarity with the concept of heat sinks and sources
  • Awareness of weather conditions that contribute to freezing scenarios
  • Research the effects of ground temperature on surface water freezing
  • Study the thermal properties of different materials, particularly in bridge construction
  • Explore meteorological factors that influence localized freezing conditions
  • Learn about the physics of heat transfer in various environmental contexts
This discussion is beneficial for meteorologists, civil engineers, and anyone involved in road safety and maintenance, particularly in cold weather conditions.
mike2007
Is it possible for water on the surface of a road to freeze even though the temperature of the air just above the road is above 0 degree celsius?
I think the answer is yes but i do not have any theories to support it.
It may be because the air above is is above 0 degrees so it tends to rise and the cooler air flows downward towards the road and thereby the road freezes.
The temperature of the ice will be affected far more by the temperature of the ground than the air above it.
Yes. One may have noticed signs in some parts of the country warning that the bridge will freeze before the road way. This is because the bridge structure is colder than the road or air. The water freezes on the bridge, which is below freezing.
In a prolonged cold environment, the ground may cool below freezing. Even when the air is warmer, if the ground is below freezing, then moisture could freeze on the ground.
One has to look at the heat sinks and sources, and the flow of heat.
  • · Replies 16 ·
