How Do You Sketch Level Curves for f(x,y)=3-y-x^2 at k=0, 2, 4?
  • Context: Undergrad
  • Thread starter Thread starter p4nda
    Function Variables
The discussion revolves around sketching level curves for the function f(x,y)=3-y-x^2 at specific values of k (0, 2, and 4). The focus is on understanding how to represent these curves in the xy-plane and the implications of doing so for visualizing the surface described by the function.
  • Homework-related
  • Some participants explain that level curves represent a contour map where points (x,y) yield the same function value.
  • There is a question about the meaning of k, with some suggesting it refers to f(x,y).
  • One participant suggests sketching the graphs of the equations 3-y-x^2=0, 3-y-x^2=2, and 3-y-x^2=4, noting that these represent parabolas.
  • Another participant elaborates that setting f(x,y) equal to k simplifies the graphing process by reducing the number of variables involved.
  • One participant asserts that equating k with f(x,y) for the specified values is sufficient to define the surfaces at each level.
Participants generally agree on the method of sketching level curves and the interpretation of k, but there is some uncertainty regarding the initial understanding of k's definition.
Some assumptions about the definitions of level curves and the function itself may not be fully articulated, and the discussion does not resolve the initial confusion about the meaning of k.
p4nda
Sketch the level curves in the xy-plane of f(x,y)=3-y-x^2 for k=0,2,4.
Anyone mind helping/teaching me how to do these type of problems?
level curves mean contour map. like those isobar chart you see during the weather report. ie. you join all the points that are of the same value , here it means join all the points (x,y) giving you the same f(x,y).
by the way what is k? is it f(x,y)?
Sketch the graphs of 3- y- x^2= 0, 3- y- x^2= 2, and 3- y- x^2= 4. Those are all parabolas.
just to elaborate a little... This question is asking you to draw out level curves because the level curves can give a fairly clear picture of what the surface is while dealing with less variables.
you set f(x,y) = k where k is a number (usually, but not always, an integer) you get rid of one of the variables thereby making it much easier to graph a piece of the surface.
So you set f(x,y) to each of the numbers given as k, and graph the parabolas (exactly as HallsofIvy described). From there, you should be able to have some ideas about what the surface looks like.
It is sufficent to equate k=0,2,4,... with f(x,y) to have a surface at each level.
Thanks.
Mr Beh
  • · Replies 17 ·
  • · Replies 32 ·
  • · Replies 16 ·
