Does Oxidation of Toluene with Potassium Permanganate Affect Acidity?
  • Thread starter Thread starter Soaring Crane
    Compounds
The discussion centers on the oxidation of toluene using potassium permanganate, specifically examining the effects on acidity and the reaction mechanism involved. Participants explore theoretical aspects, potential products, and the implications of reaction conditions, including pH changes and the formation of benzoic acid.
  • Some participants propose that the oxidation of the methyl group in toluene leads to the formation of benzoic acid, which would increase acidity.
  • Others argue that protecting the benzene ring is necessary to prevent its breakdown during the reaction.
  • There is a question about the effect of HCl volume on the purity of benzoic acid, with some suggesting that excess HCl may be needed to avoid unwanted side products.
  • Participants discuss the reaction mechanism, with one suggesting that toluene is first oxidized to benzaldehyde before being further oxidized to benzoic acid.
  • Some express uncertainty about the aqueous state of benzoic acid in the reaction mixture before acidification, questioning the correct terminology for the product's state.
  • There are discussions about the pH changes during the reaction, with conflicting views on whether the pH increases or decreases as benzoate and hydroxide are formed.
  • One participant notes that the pKa of toluene is not relevant in this context, as the formation of a benzylic anion is unlikely under the reaction conditions.
  • Several participants seek clarification on the reduction of MnO4- to MnO2 and its implications for the reaction's pH.
Participants express multiple competing views regarding the effects of the oxidation on acidity, the reaction mechanism, and the pH changes during the reaction. The discussion remains unresolved with no consensus reached on these points.
Participants note that the reaction occurs under basic conditions, which may influence the pH and the state of the products. There are also references to stoichiometry and the potential for unwanted side products, but these aspects are not fully resolved.
Soaring Crane
In the oxidation of the side chain in toluene with potassium permanganate and water as the reagents, does the acidity increase as the redox reaction is carried out?
Thank you.
Actually, you would never carry this reaction out without protecting the benzene ring, because of the methyl group on the ring, it gets activated, and acts as a reducing agent. Thus, the benzene ring undergoes the possibility of breaking apart.
If just the methyl group is oxidized, then it gets converted to -COOH, so yes the acidity will increase. Any alkyl group attached to the benzene ring when oxidized gets converted to acid and co2.
For the final product, does the number of mL of HCl added to the reaction mixture affect the purity of the benzoic acid obtained? (Does it matter if I use 10 mL of HCl or 15 mL of HCl?)
Thanks.
Yeah, but that's stoichiometry. Sometimes, depending on the compound you're converting, the product and the initial reactant might react to give you a third, unwanted product, so the HCl must be in excess..
Do you know what kind of undesired product might form in this reaction? Would it be distinguishable from the crystallized benzoic acid?
I was trying to work out the reaction mechanism for the oxidation of toluene just to understand the reaction more, but I am unsure of the steps since I was following an example, the oxidation of benzaldehyde. Instead of arriving at PhCOOH from PhCH3, I got PhCHO. How do 2 oxygen atoms replace the side chain from PhCH3? (Does the mechanism show PhCH3 oxidized to PhCHO, which is then oxidized again by MnO4- to finally get PhCOOH? I’m sorry if this is a foolish question. ) How exactly does this mechanism look?
Thanks.
Thanks.
Yeah. Thats it. I don't remember the exact mechanism, but I think MnO4- forms a closed chain which is replaced by -OH groups. Since a carbon atom cannot have more than 2 -OH groups at the same time, one pair of -OH molecules give water and a =O at that position. So the three hydrogens are replaced by -OH, two of which leave as water and one of the oxygens of the two remains as a =O, hence your -COOH.
I may be wrong where the mechanism is concerned, but I am sure about the products and their order of appearance. Just google the mechanism once.
I tried using a search engine, but I mostly get reaction equations and not a mechanism or published papers that you must have an account for.
I also have another question pertaining to this redox reaction.
After KMnO4 is added to toluene and is refluxed, benzoic acid forms. However, after MnO2 is removed but before acidification occurs (before HCl is added to filtrate), is the benzoic acid, the product in the clear filtrate, in an aqueous form? (Did I use "aqueous" correctly? I know the product does not exist in a solid form as yet.)
This the the equation before acidification:
PhCH3 + 2MnO4- --> PhCOO- + 2MnO2 (precip.) + H2O + OH-
Did I mix up the aqueous state with the liquid state? I thought that if ions exist in water it would be labeled “aqueous.”
Thanks again.
I actually have no idea about that... Ill have to look it up.
Thanks again.
These oxidations are usually conducted under basic conditions. The product (benzoic acid) is converted to the water-soluble salt, potassium (or sodium) benzoate. This is in the clear filtrate.
Even though the reaction mixture occurs under basic conditions, the reaction mixture's pH still decreases as the redox reaction transpires, right?
I believe the balanced theoretical equation is:
[tex]2KMnO_4 + PhCH_3 \rightarrow\ PhCOOK + H_2O + KOH + 2MnO_4[/tex]
You will note that as the reaction progresses, for each mole of toluene reacted, one mole of potassium benzoate and one mole of potassium hydroxide is produced.
Will this raise or lower the pH?
With the formation of the benzoate and hydroxide, won't the pKa values be lower than that of toluene (pKa = 41), so the pH is lowered?
The pKa of toluene has no bearing here. The likelihood of toluene deprotonating to form benzylic anion is vanishingly small under these conditions. Anyway, there are two phases in this reaction... the aqueous (K2MnO4/OH-) and the organic (toluene). pH is not really relevant to the organic phase and the aqueous phase has a very strong base present.
So the pH actually does increase? (It's only after acidification, not oxidation, that the pH decreases?)
In the theoretical equation, doesn't the MnO4 get reduced to MnO2?
The oxidation produces a molecule of benzoate and a molecule of hydroxide. What will the pH do?
Write out the half reaction for that transformation. Pay attention to the oxidation state of manganese.
I still don't understand. If the aqueous phase is basic and 1 mol of benzoate is produced along with one mol of hydroxide, will the reaction mixture become neutralized, so the pH lowers?
9K
23K
  • · Replies 28 ·
13K
