Signals and Systems: Response of LTI systems to Complex Exponentials
The discussion focuses on evaluating the integral for calculating the Amplitude Factor of a Linear Time-Invariant (LTI) system with a time shift of 3, represented by the equation y(t) = x(t - 3). The derived transfer function is H(s) = e^(-3s). The mathematical foundation involves the Laplace Transform, where Y(s) = H(s) X(s) and the relationship between the input x(t) and output y(t) is established through the impulse response h(t).
  • Understanding of Linear Time-Invariant (LTI) systems
  • Familiarity with Laplace Transform (specifically, \mathcal{L})
  • Knowledge of convolution operators in signal processing
  • Basic calculus for evaluating integrals
  • Study the properties of Linear Time-Invariant (LTI) systems
  • Learn about the Laplace Transform and its applications in signal processing
  • Explore convolution and impulse response in the context of LTI systems
  • Investigate time-shifting properties in signal analysis
Students and professionals in electrical engineering, control systems, and signal processing who are looking to deepen their understanding of LTI systems and their mathematical foundations.
mayan
How will we evaluate the integral for calculation of Amplitude Factor for an LTI system for which the input and output are related by a time shift of 3, i.e.,
y(t) = x(t - 3)
The answer is: H(s) = e^(-3s)
I want to understand the Mathematics behind the evaluation of the integral.
Thanks.
i'm not sure how the title of your post is related to the content.
by definition, on the left side you have,
[tex]Y(s) = \mathcal{L} \left\{y(t)\right\} = \int_{-\infty}^{+\infty} e^{-st} y(t) \,dt[/tex]
and, also by definition,
[tex]X(s) = \mathcal{L} \left\{x(t)\right\} = \int_{-\infty}^{+\infty} e^{-st} x(t) \,dt[/tex]
and, it turns out that for LTI systems, after you show that the convolution operator and some impulse response is what relates the input x(t) to the output y(t), then
[tex]Y(s) = H(s) X(s)[/tex]
where
[tex]H(s) = \mathcal{L} \left\{h(t)\right\} = \int_{-\infty}^{+\infty} e^{-st} h(t) \,dt[/tex]
and h(t) is the impulse response of the LTI system and completely characterizes the input/output relationship of the LTI system.
now, in your specific case,
[tex]Y(s) = \mathcal{L} \left\{y(t)\right\} = \mathcal{L} \left\{x(t-3)\right\} = \int_{-\infty}^{+\infty} e^{-st} x(t-3) \,dt[/tex]
which, after you do a trivial substitution of variable of integration is
[tex]Y(s) = \int_{-\infty}^{+\infty} e^{-s(t+3)} x(t) \,dt = e^{-s \cdot 3} \int_{-\infty}^{+\infty} e^{-st} x(t) \,dt = e^{-s \cdot 3} \cdot X(s)[/tex]
which means that
[tex]H(s) = e^{-s \cdot 3}[/tex].
  • · Replies 0 ·
