Finding Asymptotes in Equations: \frac{2x-3}{x-1} and \frac{5(12x+65)}{x^2-25}
  • Thread starter Thread starter Schrodinger's Dog
    Asymptote
The discussion revolves around finding asymptotes for the rational functions \(\frac{2x-3}{x-1}\) and \(\frac{5(12x+65)}{x^2-25}\). Participants explore vertical and horizontal asymptotes, questioning the methods used to determine these characteristics.
  • Mixed
  • Participants discuss the identification of vertical asymptotes, specifically noting \(x=1\) for the first function. There is confusion regarding the limit process as \(x\) approaches infinity and how it relates to horizontal asymptotes. Some participants attempt to clarify the method of dividing by the highest power of \(x\) to find limits.
  • In the second function, participants express uncertainty about the values used in the numerator and denominator, questioning the existence of horizontal asymptotes and the implications of their findings on graph sketches.
  • There is a discussion about the behavior of horizontal asymptotes in relation to vertical asymptotes and how they may not apply in certain regions.
The conversation is ongoing, with participants providing insights and clarifications about the methods for finding asymptotes. Some guidance has been offered regarding the limit process and the behavior of functions at infinity, but there is still a lack of consensus on specific outcomes and interpretations.
Participants note that the discussion is complicated by the nature of the functions involved and the potential for misunderstanding the asymptotic behavior, particularly around vertical asymptotes and the origin. There is also mention of the limitations of textbook explanations regarding these concepts.
Schrodinger's Dog
[tex]\frac{2x-3}{x-1}[/tex] find the asymptotes of this equation.
We already know that x=1 is a vertical asymptote from calculating the domain.
the denominator of x-1=0 when x=1.
However I'm not sure what it is they mean when later they go onto say..
[tex]f(x)=\frac{2x-3}{x-1}=\frac{2-\frac{3}{x}}{1-\frac{1}{x}}=\frac{2-0}{1-0}=2 as x\rightarrow \infty[/tex]
What value of x are they using here?
Another more complicated one.
I don't know what to do to achieve the same say for this:-
[tex]\frac {5(12x+65)}{x^2-25}}[/tex]
What exactly are they doing when they insert the value of x? It doesn't appear they have the same value for x as they do in the numerator as the denominator? :rolleyes:
This for a graph sketching exercise, by finding certain values you can make a sketch, would I be correct in assuming that there would be a horizontal asymptote in the equation above at y=60, and of course x=-5 and 5 Or am I missing something here?
[tex]\frac{60x+\frac{325}{x}}{x^2-\frac{25}{x^2}}=\frac{60}{1}[/tex]
I think I'm missing something here.
For the first one they let x tend to infinity and thus the denominator going to infinity makes the fraction tend to zero. That means that there is a non-vertical asymptote at f(x) = 2.
If the numerator is of greater order than the denominator then you'd do a polynomial division and the asymptote would be the leading straight line term.
Above, they are just finding the limit of the function as x tends to infinity. This is a standard method of finding limits of quotients of polynomials: divide through by the highest power of x and then use the fact that 1/x tends to zero as x tends to infinity.
I'm not sure what you're doing here.
The second example you'll have to divide the numerator and denominator by x2 then investigate as x tends to plus or minus infinity.
That makes a lot more sense, they don't explain what they have done at all really particularly well, I'll take a look bearing that in mind.
Neither was I that was kind of the point, :smile: thanks all though.
[tex]\frac{\frac{60x}{x^2}+\frac{325}{x^2}}{\frac{x^2}{x^2}-\frac{25}{x^2}}\rightarrow\frac{\frac{60}{x}-0}{1-0}[/tex]
What would I do now?
I mean I can see [itex]\frac {x}{x^2}[/itex] tends to zero? [itex]x\rightarrow\infty[/itex]
I get it with the simple example but what do I do when I end up with x/x^2?
EDITED: to try the second one, still don't understand what I'm going to end up with here? In the case of 60/x then as x tends to infinity x becomes 0? But then this means the answer is 0? Is that right?
You will notice that sometimes horizontal asymptotes don't work within the region of vertical asymptotes and the origin and often only apply as x tends to infinity in the positive and negative direction.
Sorry I edited the previous post^^, am I looking a this correctly?
I understand now what they mean but I'm still not sure what the answer would be, is it 60/x? Or do I then go further?
I looked at the graph on Mathcad, there appears to be an asymptote at -5,5, I don't think there exactly is a horizontal asymptote at y=0? There appears to be one at ~y=-4 although I could be imagining it.
It would of course tend to 0/1 which is just 0. Therefore there is a horizontal asymptote at y=0. As I mentioned before its sometimes not very good around the origin which you can see on your graph and thus there won't be one at y = -4.4. You will of course still get an accurate graph because your investigation of local minimums and maximums will tell you what's going on there.
Great that's fantastic Kurdt and Cristo, I did a bit of work on this yesterday for the first time, and couldn't really grasp at the time what they were driving at, but had I taken more note I would have seen it, anyway live and learn :smile:
Most textbooks I've seen never explain this concept properly. They just kind of introduce it and never explain that a horizontal asymptote sometimes only works for very large or very small x. And they almost always never explain the method used.
My favourite undergraduate introductory text (Guide 2 Mathematical Methods) which I think is almost perfect in every other way doesn't do this either and it frustrates me immensly.
  • · Replies 27 ·
