How Does Gravity Affect a Model Rocket's Upward Acceleration?
The discussion revolves around the effects of gravity on the motion of a model rocket and comparisons with other scenarios involving acceleration and final velocity. Participants explore concepts related to kinematics and gravitational forces in different contexts.
  • Mixed
  • Participants discuss the final velocities of different objects, questioning why the final velocity of a camera dropped from a height is not zero upon impact, while a bus comes to a complete stop. There is also exploration of how gravity affects the acceleration of a model rocket and whether it should be included in calculations of upward motion.
Some participants have provided clarifications regarding the interpretation of final velocities and the role of gravitational acceleration in the context of the model rocket. There is an ongoing exploration of these concepts, with no explicit consensus reached yet.
Participants note that the original poster's questions stem from classwork rather than homework, which has implications for the forum's guidelines on posting. There is a recognition of the need for further clarification on the physics concepts involved.
MIA6
1. A shuttle bus slows down with an average acceleration of -1.8m/s^2. How long does it take the bus to slow from 9.0m/s to a complete stop? For this question, we can immediately say that the final velocity is 0m/s because it stops. Now let's take a look at the second question: A robot probe drops a camera off the rim of a 239 m high cliff on Mars, where the free-fall acceleration is -3.7 m/s^2. Find the velocity with which the camera hits the ground. Why here this final velocity is not '0' m/s because i think it hits the ground, so it stops?
2. A model rocket is launched straight upward with an initial speed of 50.0 m/s. It accelerates with a constant upward acceleration of 2.00 m/s^2 until its engines stop at an altitude of 150m. My question is its acceleration is 2.00m/s^2 upward, but do we need to consider about the gravity 9.81m/S^2 that pulls it down because that's the reason why later on it will slow down?
Thanks a lot for explanations.
For what I presume is the first question, the final velocity is the maximum velocity reached before being accelerated in the opposite direction by the normal force. For the second question, I think you can assume that the acceleration due to gravity was already taken into account by the 2.oo [tex]ms^{-2}[/tex], giving a total upward acceleration of 11.81 [tex]ms^{-2}[/tex], assuming the acceleration due to gravity does not change to a significant degree over the 150m.
homework questions in homework forums
It's not my homework question, it's just my classwork that i still didn't really understand, so i posted it and asked other people.
Semantics will get you nowhere, my friend.
Please re-read the Forum Guidelines section on Homework Help. Coursework is included, and needs to be posted in the Homework Help forums, not in the general technical forums.
https://www.physicsforums.com/showthread.php?t=5374
Now, using bel's help so far, can you please show us some of your work on the questions, and we'll try to provide some tutorial help when you get stuck.
Ok,i will post it in homework help next time. I am a new member, so i don't really know the rules. berkeman, thanks for reminding me. These two questions i have already solved, but i don't understand some details. For question 1, I still can't figure out in second example why the final velocity is not 0 as in the first one.
Do you mean the rocket one? It has a Vo, and its final velocity is that plus the extra velocity it gains due to the 2m/s^2 net acceleration. The 2m/s^2 is the actual acceleration, which is what it could do without gravity, minus the 9.8m/s^2 gravitational acceleration that it is having to fight. Does that help?
It helps, but i mean the first question about comparing the final velocity of the shuttle bus and of camera dropped from Mars. For the bus one, we know that the Vf is 0 because it comes to stop, but why the Vf of camera hits the ground is not 0? It hits the ground means it stops?
Ah, gotcha. When they say "the final velocity with which it hits the ground", they mean just barely before impact. The force of the impact will bring the velocity down to zero a short time later, but that's not what they are asking about. The train slowly decelerated to zero (smoothly), so that's why it's final velocity is zero (or infinitesimally small just before it "stops"), as opposed to the camera which has full velocity just before it "stops".
So it means the final velocity before it hits the ground, right? I thought of that, too. Btw, when the camera hits the ground, it's not gradual like the train because train slows gradually until it stops, right? but camera is like suddenly stops?
Correctomundo. Sounds like you have it. :smile:
berkeman, thanks a lot for help.
