Register to reply
Acid or Base and Chemistry of Taste
by hotgurl1
Tags: acid, base, chemistry, taste
Share this thread:
hotgurl1
#1
Jul11-07, 07:28 PM
P: 13
Can somebody tell me the color the following items turn when purple Cabbage Indicator is added:
Water
Hydrogen peroxide
Isopropyl alcohol
Saline solution
Aspirin
Pepto-Bismol
Alka-Seltzer
Tonic water
Vinegar
and can you tell me if the items listed above are Acid or Base or Neutral
Please and Thank u
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
symbolipoint
#2
Jul12-07, 12:58 AM
HW Helper
PF Gold
P: 2,796
Can you find a reference book or article which gives the pH range and colors for that "purple Cabbage" indicator material? Do you have any information about the composition of those listed materials so as to judge their effect on pH? You should be able to answer your own questions.
A quick guess is that the purple indicator may be much like phenolphalein in its pH behavior --- only a "quick guess", not necessarily the correct guess.
hotgurl1
#3
Jul12-07, 06:54 AM
P: 13
Okay I get it you want me to find the Ph scale which is the one below. Then you want me to google each item to find there ph and that should tell me the color that each one turn and if it is acidic, netural, or a base.
pH 2 4 6 8 10 12
Color Red Purple Violet Blue Blue-Green Greenish Yellow
Thank u
Symbolipoint
hotgurl1
#4
Jul12-07, 07:36 AM
P: 13
I kinda made a big mistake were using red cabbage indicators not purple, but when you make the substance its purple.
Here's how to make it:
Making Red Cabbage Indicator
Put 1/2 cup of finely chopped red cabbage leaves in a jar and add 1/2 cup of hot water. Stir and crush the leaves with a spoon so that the red pigment in the leaves colors the water.
Continue this crushing until the water has turned a distinct, rich purple color.
Strain the liquid through a coffee filter to separate it from the cabbage leaves and throw the leaves away.
***The remaining liquid is a pH indicator: a substance that can be used to determine the pH of a substance. ***
hotgurl1
#5
Jul12-07, 07:51 AM
P: 13
Use the key below to determine whether the substance is an acid, base or is neutral. Record your results in the Data Table.
If the indicator turns the test solution red or pink, the solution is an acid.
If the indicator and solution together are a purple color, this indicates that it is neutral—neither an acid nor a base.
If the indicator turns the solution blue or green, the solution is a base.
hotgurl1
#6
Jul12-07, 08:30 AM
P: 13
Can somebody tell me if im right , so far I have:
Item color acid/ base/ neutral
Water - purple - netural
Isopropyl alcohol-red-acid
Aspirin- dark pink- acid
Alka-Seltzer-blue-base
Tonic water-pink-acid
Vinegar-pinkish-Acid
Im missing:
Pepto-Bismol
Saline solution
Hydrogen peroxide
Can somebody tell me what they are and the color. I think there all bases beteween the color of blue and green but im not sure.
Help please
chemisttree
#7
Jul12-07, 11:51 AM
Sci Advisor
HW Helper
PF Gold
chemisttree's Avatar
P: 3,724
Quote Quote by hotgurl1 View Post
Im missing:
Pepto-Bismol
Saline solution
Hydrogen peroxide
Help please
I would rethink the answer for isopropyl alcohol. The rest look good.
Regarding the 'missing' ones you show... remember that pepto-bismol is a product designed to treate heartburn (acid indigestion). Of course its pink which makes it hard to observe a color change of an indicator. Saline solution has several meanings, the simplest of which is saltwater solution. It also means a saltwater solution that is formulated to accomplish something (lactated Ringers, acetated Ringers, Phosphate Buffered Saline, etc...). Some of these other types of saline have been pH adjusted to physiological pH. Hydrogen peroxide is reactive with the indicator and may bleach it. If it is dilute enough, this may not happen very quickly and you can observe a color briefly. Most commercially available hydrogen peroxide has substances in it that stabilize the reactive peroxide against decomposition. Those stabilizers can be either acidic or basic...
http://www.h2o2.com/intro/faq.html#4
hotgurl1
#8
Jul12-07, 12:04 PM
P: 13
Thank you chemisttre.
Okay so far I have Saline solution as base and the color greenish blue is that correct.
I'm still missing
Pepto-Bismol
Isopropyl alcohol
Hydrogen peroxide
chemisttree
#9
Jul12-07, 12:22 PM
Sci Advisor
HW Helper
PF Gold
P: 3,724
I wouldn't think so. Does dissolving salt (NaCl) into water affect pH? What is physiological pH?
hotgurl1
#10
Jul12-07, 01:10 PM
P: 13
I know That Salt is a base by looking through other websites that used salt to perform this experiment.
chemisttree
#11
Jul12-07, 01:53 PM
Sci Advisor
HW Helper
PF Gold
P: 3,724
Those websites were wrong about salt....
JGM_14
#12
Jul14-07, 01:08 AM
P: 158
salt is the substance formed when an acid reacts with a base, eg. HCl+NaOH=NaCl+H2O so it is neither an acid or a base, but some residual NaOH can make it basic, NaOH is a strong base so even a little would turn it basic
what is your margin of error?
how pure is the salt?
I'm still missing
Pepto-Bismol
Isopropyl alcohol
Hydrogen peroxide
Think of what pepto-bismol would normally be used for
CrazyMan003
#13
Sep20-07, 08:00 PM
P: 1
Your a student from Florida virtual school and you have posted an assignment. I have been notified and may have to take the necessary action!
FLVS
Register to reply
Related Discussions
Acid/Base Chemistry Biology, Chemistry & Other Homework 2
Chemistry Acid Base HELP PLEASE Biology, Chemistry & Other Homework 6
Chemistry-acid base equilibria Biology, Chemistry & Other Homework 4
Chemistry Acid and Base Biology, Chemistry & Other Homework 2
Chemistry acid and base 2 Biology, Chemistry & Other Homework 0
