Definition of 0^0: What Does it Mean?
  • Context: Undergrad
  • Thread starter Thread starter murshid_islam
The discussion centers on the definition of 0^0, exploring its mathematical implications and interpretations. Participants examine whether it should be defined as 1, left undefined, or treated as indeterminate, with references to its utility in various mathematical contexts such as power series and limits.
  • Some participants propose that 0^0 should be defined as 1 for convenience in mathematical applications, such as combinatorics and Taylor series.
  • Others argue that 0^0 is undefined, similar to 0/0, and caution against assuming it has a value without context.
  • A participant mentions that defining 0^0 as 1 is a matter of taste and utility, particularly in the context of power series.
  • There is a discussion about the limits involving 0^0, with some suggesting that the limit can yield different values depending on the approach taken.
  • One participant highlights that the function f(x,y) = x^y has a singularity at (0,0), complicating the definition of 0^0.
  • Another participant notes that while some definitions may yield 1, others lead to 0, reinforcing the idea that 0^0 is indeterminate.
Participants express differing views on the definition of 0^0, with no consensus reached. Some advocate for defining it as 1, while others maintain it is undefined or indeterminate, leading to ongoing debate.
The discussion reveals limitations in the definitions and assumptions surrounding 0^0, particularly regarding the convergence of limits and the context in which it is applied.
murshid_islam
i was wondering how 0^0 is defined? can anybody please help?
thanks in advance.
Mathematics news on Phys.org
Please can we not start a very long thread on this one? If people want to see the debates on it then search the forums.
Simply put the most logical definition of 0^0 is that it is equal to 1. This makes 'everything work' without having to make any 'except for 0 when it FOO is equal to 1' statements: partitions, functions, combinatorics, taylor series etc.
It isn't. It's an undefined statement like 0/0.
However, a lot of mathematicians like to set it equal to one, but it's really a matter of convenience. So be careful of this one.
I, and most people, define it to be [tex]0^0[/tex].
Why? Because it is useful for dealing with infinite series.
But some people do not define it. And what I hate is when a person tells me he does not define it but when he writes the power series he completely overlooks [tex]0^0[/tex]
The same way we define [tex]0!=1[/tex] (but there is actually another reason there).
We can also define in terms of the continuity of the function x^0 or x^x, or (x+x)^x or whatever you want.
The reason we define 0!=1 has very little relation to this..How many ways can we arrange nothing Kummer? Or if you want, you could take the recursive definition of the factorial function, [itex]n!= n\cdot (n-1)![/itex] and substituting n=1 gives the desired result.
The reason 0^0 remains undefined is because the limit that represents it does not actually converge. Of course we could somewhat cheat by making some assumptions, eg say that it is the limit:
[tex]\lim_{x^{+}\to 0} x^x[/tex], and that is equal to 1, but we assume that the Base and the exponent approach zero at the same rate.
The correct limit is actually:
[tex]\lim_{x\to 0 , y\to 0} x^y[/tex], which is multi valued.
What do you mean "define it to be [tex]0^0[/tex]"? Did you mean to say "define it to be 1"?
now i am really confused. is [tex]0^0 = 1[/tex] or not?
Thank you.
Yes, that is true. But that does not constitute a formal mathematical proof. The problem is that there is no proof and it is a matter of taste. My preference along with most people is to define it as 1 because it is useful in power series.
Another reason is that the Gamma function evaluated at 1 is equal to 1, and that is a generalization of a factorial. But that is another story.
No, it is an "indeterminate"- like 0/0, if you replace the "x" value in a limit by, say, 0 and get 0^0 the limit itself might have several different values.
To take two obvious examples, if f(x)= x0, then f(0)= 00. For any positive x, f(x)= x0= 1 so the limit as x goes to 0 is 1. If we want to make this a continuous function, we would have to "define" 00= 1.
However, if f(x)= 0x we again have f(0)= 00 but for any positive x, f(x)= 0x= 0 which has limit 0 as x goes to 0. If we want to make this a continuous function, we would have to "define" 00= 0.
thanks a lot, HallsofIvy. that made it pretty clear to me.
It might be still clearer now that I have edited it to say what I meant!
yeah it's clear. 00 cannot be equal to both 0 and 1. so that's why it is indeterminate. am i right?
Yes. Actually, it is possible to alter the limits slightly so as to get ANY number.
Come on people. It is not that 0^0 can be '0 and 1', but that a certain limit, x^y as x and y tend to 0 can be made to be arbitrary. That doesn't say what 0^0 is, just that the function f(x,y)=x^y has a nasty singularity at (0,0). But the symbol 0^0 has a perfectly well understood commonly accepted value as 1 for many other uses.
  • · Replies 44 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 46 ·
  • · Replies 55 ·
