Solving Tension Problem: Help for Boxes B & C in Figure 5-50
  • Thread starter Thread starter snoggerT
    Tension
The discussion revolves around a physics problem involving three boxes connected by cords over a pulley system, focusing on the calculation of tension in the cords when the system is released from rest. The masses of the boxes are provided, and the setup includes both horizontal and vertical components of motion.
  • Participants discuss drawing free body diagrams for each block and applying Newton's second law. There is uncertainty about how to relate the tensions and accelerations of the blocks, particularly regarding the unknowns in their equations.
Some participants express confusion about the tension problems and the limited information available in their textbook. Others suggest drawing additional free body diagrams and relating the equations for the different blocks to find a solution. The discussion is ongoing, with various interpretations and approaches being explored.
Participants note the challenge of having multiple unknowns in their equations and the need to derive relationships between the blocks to progress. There is an acknowledgment of the complexity of the problem due to the different masses of the blocks involved.
snoggerT
In Figure 5-50, three ballot boxes are connected by cords, one of which wraps over a pulley having negligible friction on its axle and negligible mass. The masses are mA = 28.0 kg, mB = 40.0 kg, mC = 22.0 kg.
Box A is on the table and B/C are hanging from the table from the pulley system. So B/C would be on the vertical
(a) When the assembly is released from rest, what is the tension in the cord that connects boxes B and C?
F=ma
I'm not really sure where to start for finding the tension between the 2 boxes. Any hints to get me started would be nice, thanks.
F=ma
Draw free body diagrams of each block. Apply Newton 2 for each block. What can you say about the acceleration of each block?
I'm pretty sure I drew my free body diagrams right, but that leaves me with mg, T and a. of which I only know mg, so I don't really know how to figure out my tension or acceleration. I know that Acceleration is the same for all the blocks.
You have 3 fbd's, and 3 unknowns, the tension in the cable between block A and B, the tension in the cable between block B and C, and the acceleration. Solve for these values using 3 equations with 3 unknowns.
I don't know. I'm absolutely lost right now with these tension problems. I guess I'm going to go back and re-read the chapter to see if I can get a better understanding of it. the problem is that there is about 1/3 of a page on tension in the book. thanks for the help though.
What did you come up with in your FBD's? Here's the bottom block C FBD: [tex]M_c(g) -T_c = M_c(a)[/tex]
- I had that for the block C, but I have 2 unknowns in that equation (a and T). The only other thing I could think of would be to figure out the equation for block B and then relate the 2 equations together. I'm just not sure how to set the equation up for block B since it's mass is larger than Block C.
Draw the FBD for block B and see what you get. You have 2 tension forces plus the block B weight, all acting on Block B. Tension forces always pull away from the object. Then draw the FBD of Block A. You will now have 3 equations with 3 unknowns, and the problem is solvable.
  • · Replies 47 ·
9K
  • · Replies 21 ·
