Hadamard product to Matrix product transformation
The discussion revolves around the transformation from a Hadamard product (element-wise matrix multiplication) to a classic matrix product. Participants explore the mathematical relationships and potential functions that could facilitate this transformation, particularly in the context of quantum networks.
  • One participant seeks a function that maps a matrix A to a matrix B such that the equation A.*Z = B*Z holds, with Z being a given matrix.
  • Another participant suggests a potential mapping using A = (BZ)./Z and B = (A.*Z)Z^-1, noting that the function may depend on the structure of Z.
  • A third participant expresses interest in the original poster's question and mentions encountering a similar problem.
  • A later reply challenges the possibility of the formula A.*Z = B*Z in general, providing a counterexample based on matrix rank inequalities.
Participants do not reach a consensus; there are competing views on the feasibility of the transformation and the existence of a suitable function.
The discussion includes unresolved mathematical steps and assumptions regarding the properties of matrices A, B, and Z, particularly concerning their ranks and structures.
Xadan
I've been trying to find an answer to this for some time now, if anyone can provide a definitive answer, they'll have the satisfaction of knowing that several University mathematics professors haven't been able to come up with one...
I am looking for a way to transform from a Hadamard product (element-wise matrix multiplication) into a classic matrix product. Before I get flamed for posing a supposedly stupid question, the answer is related to quantum networks - (see -
http://archive.numdam.org/ARCHIVE/AIF/AIF_1999__49_3/AIF_1999__49_3_927_0/AIF_1999__49_3_927_0.pdf"
p. 951).
So more specifically - Let us start with a matrix Z, Z is an element of Real. Element wise multiplication is given by .*, regular multiplication is * . A ranges between 0 and positive infinity, B ranges between -infinity and positive infinity.
A.*Z = B*Z
Is there a function that maps A to B?
To provide more information, think about B. If we exponentiate it to 0, we get the identity matrix (I) . If we exponentiate it by -1 (assuming it does have an inverse) then we get Z. On the left hand side of the equation - if A is uniform (i.e. all matrix elements are identical), then we get Z. If A is the identity matrix, then we get (I). I'm chiefly interested in what happens in the inbetween states (i.e. between no change and orthogonalization). Transitioning B is straightforward (exponentiate to p where p ranges between 0 and -1). Transitioning A is less so. I get the feeling that the answer has something to do with rotation, but it's n-dimensional...
Any advice (or references) would be appreciated. Thanks!
To map between A and B, I guess you can use A = (BZ)./Z, and B = (A.*Z)Z^-1. The function is probably dependent on the structure of Z, and therefore Z can't be separated out.
If that's the case, then what is the function that transitions from identity (I) through Z and then to uniform (all values are 1/n)?
Hi,
I was wondering if you found an answer to your question. I stumbled on a similar problem.
Thanks.
The formula A.*Z=B*Z is not possible in general. Here is a counter example using a matrix rank inequality.
We have rank(A.*Z)=rank(B*Z)<=min(rank(B),rank(Z)).
Let A=[1 -1;1 1]' and Z=[1 1;1 1]', then rank(A)=2 and rank(Z)=1. Pick whatever B you like,
then 2=rank(A)=rank(A.*Z)<=min(rank(B),rank(Z))=1 which is impossible
and we have a counter example.
  • · Replies 52 ·
  • · Replies 17 ·
  • · Replies 19 ·
  • · Replies 27 ·
  • · Replies 20 ·
