Definition of limit n continuity
The discussion revolves around the concept of limits and continuity in single and multivariable functions. Participants explore the definitions of limits, the necessity of limits for continuity, and the use of open disks in multivariable contexts.
  • One participant questions why a function may not be defined at a point while still having a limit, suggesting that if a function is defined everywhere, continuity should not be an issue.
  • Another participant clarifies that the open disk definition is a generalization of the single-variable limit definition and discusses the relationship between convergence of sequences and open intervals.
  • A third participant introduces the concept of neighborhoods in topology, stating that convergence can be defined in terms of neighborhoods rather than just disks.
  • One participant emphasizes that continuity involves comparing the function value at a point with values at nearby points, necessitating the use of limits defined in terms of values away from the point of interest.
  • A later reply provides an example of a function that has a limit at a point where it is not defined, illustrating that limits can exist independently of function values at specific points.
Participants express differing views on the necessity of limits for continuity and the role of open versus closed disks in definitions. The discussion remains unresolved, with multiple competing perspectives on these concepts.
Some participants highlight the complexity of defining limits and continuity, noting that the definitions may depend on the context and the specific properties of the functions being discussed.
strugglinginmat
I am trying to understand the concept of limit for a single variable case. I don't understand why while defining a limit a function may not be defined at the point? For a function to be continous, why should we care about the existence of limit when we can define the function at every point on the real line?
For the multivariable case, I haven't grasped the idea of open disk in the definition? Why do these definition have open disk as constituent? Why can't close disk be included?
Help will be appreciated.
thanks
I don't really understand what you're asking in your first two questions. Can you be more explicit? What does defining the function at every point in R have to do with continuity?
As for your second question, the open disk definition is just an attempt to generalize the single variable definition. Let's take the definition of convergence of a sequence of real numbers (x_n) to some real number x: for every e>0 we can find a positive integer N such that if n>N then |x_n - x|<e. If we look more closely, the definition is saying that for any e>0, no matter how small, we can make terms of the sequence (x_n) lie in (x-e, x+e) after a certain point. Now note that on the real line an open disc is just an interval, and an interval of x will contain some 'symmetric' interval of the form (x-e, x+e) if e is chosen small enough. So we can rephrase the definition: for any open disc D containing x, we can find an N such that x_n is in D for all n>N.
As to why we choose open discs, it's just a matter of convention. Try proving that if we replace "open" with "closed" we get equivalent definitions. (Hint: inside each open disc we can fit a concentric closed disc, and vice versa.)
In fact, it needn't even be a disc.
For example, in topology, convergence is defined in terms of "neighborhoods", where a neighborhood of x is basically just a set which contain an open set which contains x (note that intervals on the real line, and both open and closed discs fit this definition in the "special" cases of [itex]\textbf{R}[/itex] and [itex]\textbf{R}^n[/itex]). We just need something to express (that is, rigorously define) the meaning of "closer to" in the sentence
the 'closer to' a we take x, the 'closer' the function value f(x) will be to the limit [itex]\lim_{x \to a} f(x)[/itex],
which defines the concept of limit.
the whole idea of continuity is to compare the value of a function at a point x, with the values at points which are different from x but near x.
thus you need two differenbt concepts, one which describes the vakue at x, that's easy its just f(x). but it is harder to describe the values away from x. there are so many of them. that's where the limit definition comes in.
the limit however must be described purely in terms of values f(y) for y not equal to x, or else it wouod not be useful.
so the limit of f(y) as y approaches x, is the value thT IT LOOKS AS IF F SHIOULD HAVE AT X, MERELY FROM LOOKING AT OTHER values of f(y).
then we compare it to f(x) to see if f has the value it "should" have. continuious functions do. i.e. a continuius function is one such that you can predict f(x) by knowing f(y) for all y near x but still different from x.in two variables you have more points near x, so you have to allow them on all sides, so you have a whole disk of them.
To answer your first question, consider the function f(x)=x/x. Now you might be tempted to say that x/x=1 and so the function is defined everywhere, and it's limit exists everywhere. But, as it turns out, the second statement is true and the first one is false.
The function has a limit everywhere. [tex]\lim_{x\mapsto a} f(x) =1[/tex]
However, the function does not have a value at x=0. f(0)=0/0 which is not defined. So it is possible for the limit to exist at a point even if the function has no value there.
Of course with a discontinuous function, it's possible for the limit to exist at a point and the function to be defined at the same point, but that these two values do not coincide at that point. You have to use piecewise definition for this or something like it. A regular relation won't get you this I think.
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 36 ·
  • · Replies 16 ·
  • · Replies 53 ·
