Why can sqrt(1+x) be approximated by 1+x/2 for small x?
  • Context: Undergrad
  • Thread starter Thread starter de1irious
    Approximation
The discussion centers around the approximation of the square root function, specifically why sqrt(1+x) can be approximated by 1+x/2 for small values of x. Participants explore the theoretical underpinnings of this approximation, including references to the binomial theorem and Taylor series expansions.
  • One participant suggests that the approximation of sqrt(1+x) by 1+x/2 for small x may relate to a theorem or infinite series where higher-order terms become negligible.
  • Another participant confirms that the binomial theorem and binomial expansion are relevant, noting that for small x, terms like x^4 can be neglected in approximations.
  • A different perspective is offered, suggesting that visualizing the graphs of sqrt(1+x) and 1+x/2 could provide intuitive understanding.
  • One participant mentions the Taylor series expansion of the function, indicating that it aligns with the inverse power binomial series.
  • A detailed explanation of the Taylor series for sqrt(1+x) is provided, including the Lagrange remainder and conditions for accuracy of the approximation.
Participants generally agree on the validity of the approximation and its relation to the binomial theorem and Taylor series. However, there are multiple approaches and perspectives on how to understand and visualize the approximation, indicating a lack of consensus on a singular method of explanation.
The discussion includes various mathematical concepts such as the binomial theorem, Taylor series, and the Lagrange remainder, but does not resolve the specific conditions under which the approximation holds or the implications of higher-order terms.
de1irious
For small x, it seems sqrt(1+x) can be approximated by 1+x/2. Why exactly is this? Is there a theorem that I can refer to? Some kind of infinite series where the x^4 power term dies out?
Thanks!
Sure. It's exactly what you said. It's just the binomial theorem and the binomial expansion. Remember that for small x, x^4 is much smaller than x^2 and can be neglected if an approximation is desired.
Or you could think of it even more easily. Draw a rough sketch of the graph. And then draw the graph of 1 + x/2. I think you will notice something :)
nvm this is easy. thanks for the help
You can also get the taylor series of the function about 0, but as has already been mentioned, this would be given by the inverse power binomial series anyway.
Let [tex]f(x) = \sqrt{1+x}[/tex]. Let [tex]-r<x<r[/tex] ([tex]0<r<1[/tex]). The Taylor Series of [tex]f(x)[/tex] centered at 0 is:
[tex]1 + \frac{x}{2} - \frac{x^2}{4}+\frac{3x^3}{8}-...[/tex].
The Lagrange Remainder as you posted is,
[tex]R_1(x) = \frac{f''(y)}{2!}x^2[/tex] for some [tex]y[/tex] between [tex]0[/tex] and [tex]x\not =0[/tex].
Now,
[tex]|R_1(x)| = \left| \frac{f''(y)}{2!}x^2\right| \leq \left|-\frac{1}{4} \cdot \frac{(1+y)^{-3/2}}{2!}\right|r^2\leq \frac{r^2}{8}[/tex]
The term [tex]\frac{r^2}{8}[/tex] determines the accuracy. Say we want your approximation to work for 2 decimal points then we require that [tex]\frac{r^2}{8} \leq .009[/tex] thus [tex]r\leq .26[/tex]. Which means if you pick a fourth, that is, [tex]r=.25[/tex] then on the interval [tex](-.25,.25)[/tex] your approximation must be accurate to at least two decimal places.
  • · Replies 19 ·
