Is There Anyone There Who Could Answer This please
  • Thread starter Thread starter libido_07
The discussion revolves around kinematic problems involving the motion of objects under the influence of gravity. Specifically, it addresses a scenario where a ball is thrown downward and a stone is dropped from a height, with participants exploring the calculation of final velocities and the time taken to fall.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of kinematic equations and the conservation of energy principles. Some express confusion over the application of formulas and the assignment of direction for acceleration and displacement. Others question the assumptions made regarding initial velocities and the choice of positive direction.
The discussion is active, with participants providing various approaches to the problems. Some have offered corrections and clarifications regarding the equations used, while others are exploring different interpretations of the problems. There is no explicit consensus, but several productive lines of reasoning are being examined.
Participants note the importance of showing work in homework submissions and the potential for multiple methods to solve the problems. There is also mention of the need to clarify the initial conditions and assumptions regarding directionality in the context of the problems presented.
libido_07
Is There Anyone There Who Could Answer This...please!
A ball is thrown downward at 5 m/s from a roof 100 m high. What is the velocity when it reaches the ground?
A stone is dropped from cliff after it has fallen 30 m. What is its velocity?
Vf^2=Vi^2+2ad for both questions
Vf= final velocity
Vi= initial velocity
There are no formulas or anything? If this is homework, surely you must know SOMETHING about it!
You must show some work. In fact, one difficulty with your not giving any attempt at all is that we don't know what you have to work with. I can think of several ways of doing this problem, ranging from plugging numbers into a given formula to solving a differential equation, but don't know which of them is appropriate for your class.
Here is the equation used to try to answer it...
1. A stone is dropped at a cliff after it has fallen 30 m. What is the velocity?
Given: Vi=0; d= 30 m; Vf=? g = -9.8 m/s^2; sqrt(Vf )= sqrt(Vi + 2 g d)
sqrt(Vf) = sqrt(0 + 2 (-9.8 m/s^2) (30 m))
= sqrt(-588 m)
=24.25 m/s
2. A ball is thrown downward at 5 m/s from a roof 100 m high. What is the velocity when it reaches the ground?
Given: g = -9.8 m/s^2; d = 100 m; Vf = ?; Vi= 0;
Vf = 5 m/s + (2 (-9.8 m/s^2) (100m))
= 25 m/s + 1960 m/s
= 1985 m/s
3. A stone is dropped from a cliff 490 m above its base. How long does the stone take to fall?
Given: t = ?; Vi = 0 m/s; d = 490 m; g = 9.8 m/s^2
d = (Vi t )+ ((g (t^2))/2 )
490 m= 0 + ((9.8 m/s^2 (t^2))/2)
490 m = 4.9 m/s^2 (t^2)
490m/4.9 m/s^2 = t^2
sqrt(100 m^2/s^2) = sqrt(t^2)
10 m/s=t
With these problems one need to choose a positive direction (direction of positive y axis?). All kinematic quantities are then assigned either positive or negative values according to their directions.
You implicitly chose upwards as positive by assigning g = -9.8 m/s^2
This means that downwards directions (and velocities) will be negative. Like in the first problem d = - 30 meters.
For these problems it might be easier to choose downwards as positive.
Well, of course, the left side is not "sqrt(Vf)", just Vf itself. You are, in effect, using "conservation of energy". Initially the potential energy (relative to the base of the cliff) is -9.8*30 times mass and kinetic energy is 0. At the bottom the potential energy is 0 so all that energy has been converted to kinetic energy.
= sqrt(-588 m)
=24.25 m/s
Yes, that is correct.
Vf= Vi+ 2gd ??
I certainly don't recognize this formula! It doesn't even have consistent "units" (2 (-9.8 m/s^2) (100m)) has units of m^2/s^2, not m/s.
= 25 m/s + 1960 m/s
= 1985 m/s
Better to use the same method you did before, except that now the initial speed is 5 m/s: total energy at the top is (1/2)mVi^2+ mgd while total energy at the bottom is (1/2)mVf^2: (1/2)mVf^2= (1/2)mVi^2+ mgd so
Vf^2= Vi^2+ 2gd.
10 m/s=t
Good - except that (490m/ 4.9 m/s^2 is 100 s^2, not 100 m^2/s^2- meters cancel, not multiply). Of course that means that the answer is
t= 10 s, not 10 m/s which is a good thing since this is supposed to be a time!
Isn't that just basic SUVAT.
i.e.
v=u+at
v^2=u^2+2as
s=ut+(1/2at^2)
s+vt-(1/2at^2)
where:
a = acceleration (9.81)
u = inital velocity
v = final velocity
t = time
s = displacement
did you guys uses conservation of energy?...why?
