- 1,108
- 1
Here are three questions. Feel free to answer any or all. Question #1 you can work out with some simple algebra. I will warn you that the other two questions are not ones you are likely to be able to answer just by straining your brain. You will probably only be able to answer #2 and #3 by drawing upon your knowledge of algebra and geometry, respectively. Good luck.
1. Label the end points of a line segment with A and B. Place a point C on the segment such that AC is longer than CB, and more particularly that the ratio of the length of AC to that of CB is the same as the ratio of AB to AC. Calculate the ratio AC/CB. Does the number look familiar to you? Bonus points for identifying which mathematician wrote on this topic: “A straight line is said to have been cut in extreme and mean ratio when, as the whole line is to the greater segment, so is the greater to the lesser.”
2. What ninth and final number x completes this set?
{-1, -2, -3, -7, -11, -19, -43, -67, x}
3. What is the pattern in this sequence?
infinity, five, six, three, three, three, three,... (threes continuing forever)
In other words, what sort of mathematical pondering might have led to this sequence, where the ordering of the terms comes out like this in a natural way.
I'll give the answers in a day or two if there are any remaining unanswered.
