Design Board w/ TPS61032: Connecting Pins?
  • Thread starter Thread starter KoZuEst
    Data
The discussion revolves around the design considerations for connecting pins on the TPS61032 DC-DC converter, particularly regarding the multiple pins assigned for the same function, such as SW, PGND, and VOUT. Participants explore layout recommendations and the importance of proper connections in the context of PCB design for power electronics.
  • Homework-related
  • One participant questions whether to connect all pins assigned for the same function or just one, indicating a lack of experience in board design.
  • Another participant suggests connecting all pins as shown in the datasheet and emphasizes the importance of PCB layout for DC-DC converters.
  • A participant notes that the TPS61032 may not be widely used, expressing concerns about availability and shipping costs for alternatives.
  • It is mentioned that multiple pins are used to increase current handling capacity, implying a rationale for connecting all relevant pins.
  • A reference to the datasheet's layout considerations suggests using wide and short traces for the main current path and power ground tracks, proposing a specific approach to connecting the VOUT and PGND pins.
Participants express differing views on whether to connect all pins or just one for each function, with some advocating for connecting all while others seek clarification on the necessity of this approach. The discussion remains unresolved regarding the best practice for pin connections.
Participants reference specific layout considerations from the datasheet, indicating that there may be additional assumptions or dependencies on the design context that are not fully explored.
KoZuEst
Take a look at this data sheet http://www.datasheetcatalog.com/datasheets_pdf/T/P/S/6/TPS61032.shtml" and tell me this:
There are multiple pins assigned for the same function. there are two pins for SW and three for PGND and VOUT each. Do I only need to connect one of each pins or connect them all. I'm designing a board for the first time here.
thanks
--KoZu
Absolutely connect them all as shown in the datasheet schematics. And layout is very important for DC-DC converters like this, so it would be best if you could find some recommended PCB layout patterns to start with.
Have you looked at the National Instruments "Simple Switcher" series of DC-DC converts as an alternative? I think they tend to give sample 1-layer and 2-layer layout examples for those designs. Or at least do some more searching in the TI application note literature to see if you can find an example layout.
I did some research, looks like this isn't a very used converter, but to me it was pretty much the only one available to suit my needs, unless I want to order directly from a manufacturer in which case the shipping alone would cost ten times more than the chip itself.
So.. when I build this thing, I connect the three VOUT etc. pins together?
Yes, they use multiple pins to increase current handling capacity.
On page 13, "Layout Considerations", it says
"use wide and short traces for the main current path and for the power ground tracks."
I would interpret that as "make one wide track on the PCB connected to the three VOUT pins on the chip" and the same for the three PGND pins.
  • · Replies 23 ·
  • · Replies 25 ·
