nemzy
- 124
Does it? proof please?
The discussion centers around the mathematical question of whether 0.9999... is equal to 1. Participants explore various proofs, definitions, and interpretations related to this concept, engaging in both technical reasoning and conceptual clarification.
Participants generally disagree on the equality of 0.9999... and 1, with multiple competing views presented. While some assert that the equality is established, others maintain that it is not universally accepted, leading to an unresolved discussion.
Some participants express concerns about the definitions used in the discussion, particularly regarding the nature of infinite sums and the properties of real numbers. There are also references to historical figures in physics to illustrate points about the nature of mathematical truths.
How infinitely many elements can have a sum?0.999... is DEFINED AS the sum of the geometric series...
Sigh, no it is the limit of n approaching infinity. It never actually reaches infinity just as you can never write 0.999... out in full. This is barely above high school mathematics and really simple to understand if you read it and tried to learn something.Organic said:How infinitely many elements can have a sum?
All we can say is that they are approaching the sum, but never reaching the sum.
Shortly speaking, this is the all idea of being infinitely many ... .
Standard Math breaking its own rules by saying that .999... = 1
Organic said:Standard Math breaking its own rules by saying that .999... = 1
Demonstrate a zero gap between 0.999... and 1if you do not believe that 0.999... = 1, it should be very easy for you to prove it. find a real number between them.
Organic said:Demonstrate a zero gap between 0.999... and 1
pig said:don't you agree that for every non-zero real x, it is correct that: |1 - 0.999...| < |x| ?
since by substracting 0.999... from 1 we get infinitely many 0s after the decimal point, the result is smaller than any number which has a non-zero digit.
unless you consider things which make no sense like "0.000...0001" real numbers.
and that leaves zero as the only possible solution in R.
Organic said:Sure Chroot, it is closed exactly like Lord kelvin once said about Physics, and then Plank came ...
