Mixer (Modulator, Frequency Multiplier whatever)
  • Thread starter Thread starter kent
    Frequency
The discussion focuses on selecting a mixer for down-converting a 20 MHz sinusoidal signal to a 10 kHz signal using a synchronous detection circuit. The LM1496 chip is mentioned as an older option, prompting the search for newer alternatives. Mini-Circuits is recommended as a valuable resource for modern mixers, with suggestions to utilize their selector guides for optimal product selection. Retailers like Digikey and Mouser are noted as potential suppliers for Mini-Circuits products.
  • Understanding of synchronous detection circuits
  • Familiarity with signal generation and frequency modulation
  • Knowledge of mixer specifications and part numbers
  • Basic skills in sourcing electronic components from distributors
  • Research Mini-Circuits mixer options for frequency conversion
  • Explore the specifications and applications of the LM1496 mixer
  • Learn about modern alternatives to the LM1496 for signal mixing
  • Investigate the use of selector guides for electronic component selection
Electronics engineers, hobbyists building RF circuits, and anyone involved in signal processing and frequency conversion applications.
kent
Hi guys
I am now building a simple synchronous detection circuit, I have now two signal generators, one generate a 20 MHz sinusoidal signal, and the other one gives a 19.99 MHz signal. If now I want to down-convert the 20 MHz signal into a 10 kHz signal, what kind of mixer (part number) can I use to achieve this kind of task?
I have been browsing the web for a long time, but at the moment I can only find a LM1496 chip (which is pretty old), I am pretty sure there are some newer and better chips which can satisfy my need
Thank you very much for ur help!
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 28 ·
  • · Replies 17 ·
