Parametric and cartesian equations? HELP
The discussion revolves around understanding the relationship between parametric equations and their Cartesian counterparts, specifically focusing on the equations x = 3t and y = 9t^2. Participants are exploring the concepts of initial and terminal points, as well as the implications of converting parametric equations to Cartesian form.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are attempting to identify initial and terminal points of the curve and question what these points mean in the context of the given parametric equations. There is discussion about how to derive the Cartesian equation and what it signifies regarding the graph's coverage.
The conversation is ongoing, with participants providing insights and guidance on how to eliminate the parameter t to find the Cartesian equation. Some participants express confusion about the concepts, while others clarify the relationship between the parametric and Cartesian forms.
There is mention of a lack of clarity in the original problem statement, particularly regarding the definitions of initial and terminal points, as well as the nature of Cartesian equations. Participants are also reflecting on their understanding of the concepts after reviewing their textbooks.
akeber0
parametric and cartesian equations?? HELP!
1. x = 3t, y = 9t^2, negative infinity<t<positive infinity
2. a) What are the initial and terminal points, if any? Find a Cartesian equation for a curve that contains the parametrized curve. What portion of the grap of the Cartesian equation is traced by the parametrized curve?:bugeye:
3. There isn't any attempt. I have no idea. Different language here.:confused:
You need to show some work before we can help you. What do you think the question means by initial and terminal points? Do you think this graph has any?
To find the cartesian form for the equation, why not use one equation to eliminate t from the other?
okay, I'm guessing the initial and terminal points mean where the graph starts and ends, and is that what a cartesian equation is? My book doesn't explain and the examples it gives don't help me grasp what the cartesian equation actually is.
Yea, so to find the starting point (x,y) evaluate (3t,9t^2) as t tends to negative infinity. To find the ending point, do the same, but evaluate it as t tends to infinity. (You should note the part of question that says find the points if any!)
Well, I presume it just means an equation of the form y=f(x) where f is some function of x. So, you can find this by eliminating t as I said above.
to get this straight:
to get the starting point i'd take negative infinity = 3t, 9t^2 and those would me my initial coordinates. I think my previous teacher said something about the number being so large that it doesn't exist so is that when i put none? and is that the same for the positive infinity when i set it to 3t and 9t^2? There aren't any points, are there?
oh and thanks for the cartesian equation now that i see the book it makes sense.
Well, yes there are no start or end points since the limits are not defined.
In fact, if you now know what the equation is, then you will see there are no start or end points.
wait, how do i know that there are no endpoints just by putting 3t, 9t^2 into the cartesian equation?
Have you found the equation in cartesian form yet? It should be quite a familiar graph.
so i set 9t^2 in for y and 3t in for x and then the equation looks like 9t^2=3t(x) and then solve for x so x=3t, but that doesn't leave me with a parametric curve. And then how is that supposed to help me find the starting and end points? sorry i haven't taken math in half a year and i feel super dumb right now.
Ok, so you have two equations: x=3t; y=9t^2 and you want to make this into an equation of the form y=f(x). So, the first equation can be rearranged to give t=x/3, which can then be substituted into the second equation, yielding y=9(x/3)^2. Can you simplify this?
okay so now that I've simplified down to the cartesian equation (y=x^2), then i substitute x^2=f(x). then how do i find out that there aren't any existing start and end points?
sorry it takes so long to reply. at the beach with limited connectivity. I've moved so it should be faster now.
No, now you've got your equation. (Forget about the f(x) part if it's confusing you; it was just my notation). So, the equation is y=x^2.
If you plot this (or simply recall what it looks like) you should be able to see that it has no start or end point. If you let x tend to infinity, the function tends to infinity, and if you let x tend to negative infinity, the function tends to negative infinity. So, you see, there are no possible start or end points.
Ok, now you've just made me incredibly jealous, as I'm sat here in rainy England!
okay so now that I've got the cartesian equation for my graph, what is the problem asking when it says what portion of the graph is being traced?
as for being in england, I'm no better off. probably worse as it's gorgeous and sunny and i have to do this homework inside all day before it's due on friday :P
Well, I may be overlooking something, but I'm sure the parametrised equation covers the whole of the graph y=x^2.
okay now I've got the answer but how did you get there? how do you know that it covers the whole thing?
And is the parametrized equation the same as the cartesian equation?
Sorry, I know it's both against forum rules, and not of much use to you to just say something like that, but I'm having some difficulty in how to actually explain this.
Ok, so the parametric equation holds for [itex]-\infty<t<\infty[/itex]. Therefore this is valid for [itex]-\infty<x<\infty[/itex] and [itex]0<y<\infty[/itex]. But this is the entire domain and range of y=x^2, and so the parametric equation covers the entire cartesian graph.
well cristo you did a mighty fine job of explaining that for having difficulty. on my next problem i might have to ask for help understanding how to get the portion of the graph that it covers.
as for the questions: The initial and terminal points are nonexistant. The cartesian equation (aka parametric equation??) is y=x^2, and the whole graph is traced by the parametrized curve. is that correct?
Yup, they would be my answers. Apart from one small point. The parametric equation and the cartesian equations are not the same, but are two different forms of the same equation. The cartesian form is the standard one, whereas the parametric form is a set of two equations for x and y, each in terms of a parameter, t (Hence the name!).
Enjoy the sun :smile:
9K
  • · Replies 16 ·
