Solving Solubility of 2-Aminobutane
  • Thread starter Thread starter Soaring Crane
    Solubility
The discussion revolves around the solubility of 2-aminobutane in various solvents, specifically NaOH, NaHCO3, HCl, and H2O. Participants explore the factors influencing solubility, including molecular weight and polarity, and examine the chemical behavior of 2-aminobutane in these solvents.
  • Homework-related
  • One participant states that 2-aminobutane is soluble in all tested solvents and questions if its solubility in H2O and NaOH is due to its low molecular weight.
  • Another participant challenges the idea that low molecular weight correlates with solubility, suggesting that polarity is a more relevant factor.
  • A participant inquires about the state of 2-aminobutane in NaOH and NaHCO3, expressing uncertainty about whether it exists as a free base or an ammonium compound.
  • It is noted that 2-aminobutane is sparingly protonated in water, with its solubility attributed to its polar nature rather than protonation.
  • Participants discuss the equilibrium expression for protonation and question its applicability to solubility in NaOH.
  • One participant suggests that the solubility in NaOH and NaHCO3 must be due to the polar nature of the free base, noting that adding NaOH typically converts amines to their free base, which can sometimes reduce solubility.
Participants express differing views on the factors influencing the solubility of 2-aminobutane, particularly regarding the roles of molecular weight, polarity, and the chemical state of the compound in various solvents. The discussion remains unresolved with multiple competing perspectives.
Participants have not reached a consensus on the exact nature of 2-aminobutane's solubility in the tested solvents, and there are unresolved questions regarding its behavior as a free base versus an ammonium compound.
Soaring Crane
See below.
See below.
For 2-aminobutane, four solubility tests were done with the following solvents:
NaOH
NaHCO3
HCl
H2O
It was soluble in all of them. Is this correct? Is it soluble in H2O and NaOH because of its low molecular weight?
Are these the correct equations for aminobutane’s results?
CH3CH2CH(NH2)CH3 + HCl ->
_________H
_________|
______H-N-H
________|
CH3CH2CHCH3 + Cl-
where N is +.
For NaOH,
CH3CH2CH(NH2)CH3 + NaOH -> ??
I’m unsure at exactly how to express the solubility in an equation.
In H2O,
CH3CH2CH(NH2)CH3 + H2O ->
_________H
_________|
______H-N-H
_________| (+ for N)
CH3CH2CHCH3 + OH- ??
In NaHCO3,
CH3CH2CH(NH2)CH3 + NaHCO3 -> ?
Again, I’m confused at expressing the experienced solubility.
Any help is appreciated.
Thanks.
Soaring Crane said:
...It was soluble in all of them. Is this correct? Is it soluble in H2O and NaOH because of its low molecular weight?...
Rethink this. It is not true that low molecular weight compounds will be soluble in water due to low molecular weight. It is more related to polar/nonpolar.
Here you are asked if the amine will exist either as a free base or as an ammonium compound.
[tex]CH_3-CH(NH_2)-CH_2-CH_3[/tex] vs. [tex]CH_3-CH(N^+H_3)-CH_2-CH_3[/tex]
Yes, but what does 2-aminobutane exist as in NaOH and NaHCO3? I found it to be soluble in both, and I don't think it exists as the ammonium compound. (If 2-aminobutane does exist as an ammonium compound, then how does this come about?) How is it soluble in these bases if it exists as a free base?
Apparently sec.aminobutane is soluble in water. In water the compound is only sparingly protonated and so its solubility must be due strictly to its polar nature and not the fact that it will be protonated or not.
the equilibrium expression for the protonation would be
[tex]CH_3CH_2CH(NH_2)CH_3 + H_2O \rightleftharpoons CH_3CH_2CH(N^+H_3)CH_3 + OH^-[/tex]
the Ka would be products/reactants and pKa would be -log[products/reactants]
Yes, but why does 2-aminobutane appear to be soluble in NaOH and NaHCO3? Can the equilibrium expression above be applied in its solubility in NaOH?
The solubility must be solely due to the polar nature of the free base (as opposed to what I wrote in my first post in this thread). Adding NaOH or NaHCO3 will not change that. Usually, NaOH is added to amines to convert them to their free base and often this is enough to render them insoluble in water. It doesn't seem to be enough to do that in this case. It is unusual IMO.
  • · Replies 48 ·
10K
15K
27K
  • · Replies 18 ·
10K
