How Does Charge Flow in Series Capacitors Affect Electric Field Balance?
The discussion revolves around the behavior of charge flow in series capacitors and the resulting electric field interactions between the plates. Participants explore the implications of charge distribution, induction, and the conditions under which charges cease to move.
  • Some participants propose that in a series capacitor setup, the outer plates induce charges on the inner plates, creating a dipole effect without direct charge flow between them.
  • Others argue that real capacitors experience leakage currents due to imperfect insulation, which can lead to incomplete charging.
  • One participant questions why electrons in the connecting wire do not move despite the attractive and repulsive forces from adjacent charges.
  • Another participant suggests that the electric field in the wire connecting the plates is zero because the fields from the charges on the plates balance each other out.
  • Concerns are raised about the implications of charge distribution and whether it leads to a situation where charging never stops.
  • There is a discussion about the equilibrium condition where forces on charges are balanced, leading to no movement of electrons in the wire.
Participants express differing views on the nature of charge flow and electric field interactions in series capacitors. There is no consensus on the implications of charge distribution and the conditions under which charging ceases.
The discussion highlights uncertainties regarding the assumptions about charge distribution and the behavior of electric fields in the context of series capacitors. The implications of these factors on charge movement remain unresolved.
pardesi
consider the plates ofa capacitor suppose u just have two capacitors connected in series then consider the two plates not connected to the battery that form a seprate system .one of them has [tex]+Q[/tex] and the other [tex]-Q[/tex]
then how is that there is no flow of charges between them because one of them repells electron(considering the net effect of that and it's 'conjugate' plate) and other attracts (considering the net effect of this it's 'conjugate' plate)
In a real capacitor there is a flow because the insulating material between the plates is obviously never a perfect insulator.
It's a common fault in electronics designs to produce a circuit which doesn;t work where the capcitors never fully charge because of the leakage current.
but the wires between the plates of two capacitors is atleast theoritically perfectly conducting
does someone have any idea...
then how is that there is no flow of charges between them ?
For the same reason a neutral piece of paper is attracted to a positivily charged comb.
It happens because, even though the piece of paper is originally neutral, the positive charge on the comb induces a dipole field on the paper.
Likewise in your case, each outer plate (connected to the battery) "induces" opposite charge on the inner plates. In effect the formerly neutral inner plates (connected together) 'act as if' they are a large "induced" dipole.
The +Q and -Q on the inner plates are only there because of induction. They don't neutralize each other for the same reason an 'induced' dipole doesn't neutralize itself.
The charges in an E field arrange themselves in such a way to try to neutralize the externally applied FIELD.
Creator:biggrin:
but my question is about the field between +Q of one plate and -Q of other plate
If I understand correctly, this is what you have in mind:
... +Q1 -Q2 +Q3 -Q4
Absolute values of all charges are equal (Q1=Q2=Q3=Q4), if both capacitors are equal. They have different labels to help the discussion. You are asking, why charges -Q2 and +Q3 do not move toward each other. Right? Indeed, there is attraction between them, and the wire presents a convenient path.
The answer is that -Q2 is also attracted to +Q1, and +Q3 is also attracted to -Q4. So, in the equilibrium situation it is unlikely that Q2=Q3=0. The equilibrium values of charges Q1=Q2=Q3=Q4 can be found by knowing capacitance values and the applied voltage.
Eugene.
no not that the capacitors move towards each other...i was talking about the intermediate electrons in the wire ...just near te negative charge they are pushed and juts near the positive they are attracted so how come the charging in this segment ever stop
I haven't implied that capacitor plates are moving. I was talking about moving charges.
There is no electric field in the wire connecting plates -Q2 and +Q3. The field created by charges -Q2 and +Q3 is exactly compensated by the field created by charges +Q1 and -Q4. Therefore, electrons in this wire are not moving.
I am not sure if you agree with my explanation, perhaps, I didn't understand your question. What is the charge distribution among all four plates, in your opinion?
Eugene.
actually it is this fact that is worrying if the charges are so distributed that the field cancel out then the charging never stops end evn if they didn't it wouldn't (may be...)
i don't have any idea sbout charge distribution
I am not sure we are talking about the same thing. The equilibrium condition is exactly when forces acting on each charge in the system are balanced. In this situation, the electric field in the wire is zero, so electrons are not moving along the wire, and the charges on capacitors plates are not changing.
Eugene.
  • · Replies 103 ·
10K
  • · Replies 18 ·
  • · Replies 101 ·
11K
