New Reply
double slit experiment whith one photon
Share Thread Thread Tools
Jul28-07, 05:09 PM   #1
From "http://physicsweb.org/articles/world/15/9/1":
In 1909 Geoffrey Ingram (G I) Taylor conducted an experiment in which he showed that even the feeblest light source - equivalent to "a candle burning at a distance slightly exceeding a mile" - could lead to interference fringes. This led to Dirac's famous statement that "each photon then interferes only with itself".
To be sure that just one photon is producing interference you need to calculate how long the photon last ( t ). Since s = c . t ( space, velocity of light and time ), this will give us a length of the photon.
"length is this experiment" an operative definition.
How can be calculated the power of ligth that must reach the double slit to be shure that there is just a photon at a time ?
2. Relevant equations
Energy of a photon E = h. nu
Energy of an electromagnetic wave E = 1/2 E . H ( per volume )
Impedance of the empty space E / H = a given number
3. The attempt at a solution
From the tree equations you can derive the volume of a photon, but:
volume = surface . length and we dont know the surface of the photon.
Besides this seems that is a nosense concept ( volume, length, surface ) when applied to a photon.
So my question is
"How was calculated the power of ligth that must reach the double slit to be shure that there is just a photon at a time ? "
I dont understand QM, so I just want an answer to my question.
Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Jul28-07, 06:07 PM   #2
Quote by alvaros View Post
So my question is
You are right, the notions of volume, length, and surface are not applicable to photons. However, you can easily calculate how many photons a light source emits each second. You need to know the light frequency [itex] \nu [/itex], the energy of each photon [itex] E = h \nu [/itex], and the energy emitted by your light source in one second. The latter quantity is called the power of the source. For example, a 100 W(att) lightbulb emits 100 Joules of light energy each second.
You'll see that the lightbulb emits a huge number of photons per second: billions upon billions... In order to reduce the rate of photon emission you can apply filters or let the light to pass through a small aperture (thus blocking a large portion of photons). You'll need to repeat this filtering/blocking procedure several times until you get to the 1 photon/second (or whatever rate you think is appropriate to call "one photon at a time") light source.
Eugene.
Jul29-07, 03:27 PM   #3
meopemuk:
I dont know what is the rate appropiate to call "one photon at a time" and this is the relevant answer I want to know.
Thanks.
Jul29-07, 05:10 PM   #4
Recognitions:
Homework Helper Homework Help
There isn't really an answer to this, it's all a question of probabilites.
If you reduce the power of the lamp so that ON AVERAGE there is only 1 photon/second emitted and the experiment is only 1foot long - the photon travels through the experiment in 1ns so there is only a 1 in 1billion chance of another photon being emitted in the same nanosecond and being in the experiment at the same time.
Are those odds good enough to convince you there is only one photon?
If not reduce the brightness so there is only one photon/hour or 1/day.
Jul29-07, 06:45 PM   #5
Quote by mgb_phys View Post
Excellent answer! I couldn't say it better.
Eugene.
Jul30-07, 03:59 PM   #6
all quotes from mgb_phys:
I understand probabilities, lets suppose that the source emits a photon exactly each certain amount of time, like a clock.
If ( ... ) there is only 1 photon/second emitted and the experiment is only 1foot long - the photon travels through the experiment in 1ns
( c = 1 feet/ns ) You are assuming that the length of the photon is 0, why ?
Can you be shure that a photon cant last 2 seconds or 10 minutes, why ?
It doesnt seem very scientific.
Im convinced that there is just a photon at a time, this is not the question.
Jul30-07, 04:56 PM   #7
From everything we know about photons, they are point-size particles with infinite lifetime.
The fact that they are sizeless particles is supported (among other things) by the observation that each photon interacts with a single AgBr cluster of the photographic plate emulsion. The fact that photons never decay or disappear is supported (among other things) by observations of distant galaxies. However, the infinite lifetime of photons does not imply that their "length" is infinite as well.
Eugene
Jul31-07, 06:30 PM   #8
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
I imagine you need to do something like the following for the problem in the OP:
Assume you have an isotropic source of power P, some distance R from the slits. Let the slit area be A - that gives you a total power through the slit. Assume the light is monochromatic at frequency f to find the photon rate, and hence the time between photons arriving at the slits. Finally, assume a distance D from the slits to the screen, and ensure that there must never be more than one photon in this space at any time.
Aug1-07, 05:22 PM   #9
To all posters: I read carefully your posts and I wanted to discuss each sentence you wrote but I want to focus in the main idea.
Lets suppose you can control exactly the rate of the photons arriving at the double slit ( 1 photon/second ... 1 photon/ns ),
which rate would you choose ? ( to be shure that each photon interferes whith itselt )
meopemuk:
The fact that photons never decay or disappear ...
From this sentence I infer that you never can be shure that there is just a photon at a time. Is there any distribution of probabilities of the "life time" of the photons ? The "life time" depends of the source ( distant galaxies ) ?
Aug1-07, 05:58 PM   #10
Suppose that the distance between your proton source and the photographic plate is 1 foot. For a photon it takes 1ns to travel this distance. So, if your source emits 1 photon per 1 ns (let's make it 1 photon per 2ns, to be certain), then you can be sure that when a photon is emitted, the previous photon has already traveled the full length (1 foot), interacted with the photographic plate, and left its mark there. So, the previous photon cannot have any effect on what the present photon will be doing. With this emission rate you can confidently say that each photon behaves on its own, there can be no any photon-photon interaction, and if an intereference pattern is formed in these conditions, then you must conclude that each photon "interferes with itself".
meopemuk: The fact that photons never decay or disappear ...
I am not sure I understand your question. I said that the "lifetime" of photons in infinite. This means that once a photon is created (e.g, in an atomic transition, or whatever) it lives forever. It travels with the speed of light until
some other atom absorbs it. The photons emitted by distant galaxies apparently haven't met any absorbers on their way to Earth. If the photons were unstable particles with a finite lifetime t, we would have trouble seeing anything at distances greater than ct from Earth.
Eugene.
Aug1-07, 11:10 PM   #11
Taking the Heisenberg uncertainty point of view, the "duration" of a photon can be related to it's bandwidth. This is how I'd approach the problem - if you know that your source is a HeNe laser, say, then you can look up it's bandwidth and calculate it's coherence length. This gives you the temporal "duration" of a photon - if the average time separation between photon emissions is longer than this, then you can say that there is very probably only one photon at a time interacting with the slits.
Aug2-07, 03:55 PM   #12
meopemuk:
The experiment doesnt change whit the distance source-double slit, the interference happens when the photon ( or two photons ) arrive at the double slit.
If your argument is true you cant set up this experiment using the photons from stars because you would need years between photon and photon.
JeffKoch:
I dont understand.
What does coherence length mean ? If the bandwith of the laser is 10 Hz, what is the coherence length ?
But I want to further explain my posts.
I want to know how is related the idea of a photon whith the electromagnetic waves. A photon is a piece of electromagnetic wave ( true ? ), so it must start and end, and occupy a certain volume.
From my first post:
Energy of a photon E = h. f
What am I missing ?
Aug2-07, 04:13 PM   #13
alvaros,
I think this is a wrong idea. In my opinion, it is more correct to imagine photon as a point particle, and the electromagnetic wave as a (sort of) wavefunction that describes the probability amplitudes of finding this particle in different regions of space.
This situation is very analogous to the QM description of the electron. We consider electron as a point particle, and not as a piece of the De Broglie wavefunction. This is a classic example of the "wave-particle duality" in quantum mechanics.
Eugene.
Aug2-07, 06:37 PM   #14
Recognitions:
Quote by JeffKoch View Post
You cannot talk about the coherence length of a single photon. The coherence length is a measure of how long the source gives 'equivalent' photons. Given that the poster is already confused about the size of a photon I don't think it is useful to imagine the coherence length as the length of a photon in an interference experiment.
Aug2-07, 09:16 PM   #15
Sure you can, in an average sense. An excellent working model of a photon (whatever that really is - in fact I was asked "What is a photon?" during my dissertation oral exam I don't think anyone can really answer this.) is a wave with a single oscillation frequency within an envelope function. A Fourier transform gives the bandwidth.
I can't think of any other measure for the "length" of a photon, though I agree that perhaps this will just confuse the poster.
Alvaros, can you clarify what - exactly - the homework question asks? Your reference is to an article, not a homework problem.
Aug2-07, 11:53 PM   #16
Recognitions:
The 'average' of a single photon (smirk)?
I got asked how many constellations there are! Ok I'm an astronomer but my Phd was in building closure phase interferometers.
Aug3-07, 02:16 PM   #17
The 'average' of a single photon (smirk)?.
More like, "an average photon" from the source.
If you have a better measure for the "length" of a photon, I'm all ears - I can't think of one that doesn't invoke the ghost of Heisenberg. You could consider lifetime instead of length, but it's the same thing.
New Reply
Thread Tools
Similar Threads for: double slit experiment whith one photon
Thread Forum Replies
The Photoelectric Effect, Photon Duality, and The Double-Slit Experiment Quantum Physics 5
Problem: Plastic Covering One Slit in Double Slit Experiment Introductory Physics Homework 5
Double Slit Experiment Quantum Physics 16
Exact solution of the double slit experiment with a single photon Quantum Physics 18
Single Photon Double Slit Experiment Quantum Physics 10
