Outside the capacitor plates E is zero how potenital the same
The discussion addresses the relationship between electric fields and potential in the context of a charged capacitor. It clarifies that while the electric field (E) is zero outside the capacitor plates, the potential is not necessarily zero; rather, it is constant and equal to the potential of the battery terminal. The conversation emphasizes that this scenario applies to an idealized parallel-plate capacitor, which is not physically realizable. In practical applications, the electric field outside a finite-sized capacitor connected to a battery is not zero, and potential decreases to zero at infinity.
  • Understanding of electric fields and potentials in electrostatics
  • Familiarity with the concept of capacitors and their configurations
  • Knowledge of idealized versus real-world physical systems
  • Basic principles of circuit theory involving batteries and capacitors
  • Study the behavior of electric fields in finite-sized capacitors
  • Learn about the mathematical derivation of potential difference in capacitors
  • Explore the concept of electric field lines and their implications in electrostatics
  • Investigate real-world applications of capacitors in electrical circuits
Students of physics, electrical engineers, and anyone interested in understanding the principles of electrostatics and capacitor behavior in circuits.
bobca117
hi,
We see theoretical discussion of Electric field inside the charged capacitor is confined in the space between the plates and E.d = potential difference between plates. Considering the battery terminal(let us say positive terminal), wire and left plate or top plate, being in the same potential, let us try calculating the potential on the outside surface of top plate. Since the electric field is zero, the work done in carrying a positive test charge from infinity to the outside surface of the top plate, will be zero. But the potential cannot be zero since battery terminal, wire and the plate are at the same potential. What is wrong here?
Bob
Correct, with a caveat that I'll discuss at the end.
Nothing. The fact that the electric field is zero in some region does not imply that the potential is also zero in that region. It implies that the difference in potential between any two points in the region is zero, i.e. that all points in the region have the same potential. In this case, that potential would equal the potential of the positive terminal of the battery.
Caveat: I'm talking about the idealized parallel-plate capacitor whose plates extend to infinity. This is not actually physically possible, of course. Besides the fact that it would take a lot :bugeye: of material to build the capaciitor, where would we put the battery and the return wire? :confused: Also, we'd have a region of zero potential extending to infinity on one side of the capacitor, and a region of constant nonzero potential extending to infinity on the other side, which isn't physically possible.
For a real, finite-sized capacitor connected in a circuit with a battery, the electric field is not zero outside the capacitor, and the potential falls off to zero as you go to infinity in any direction. Nevertheless, in a region close to one of the plates of the capacitor, in which the capacitor "looks like" it's practically infinite, the potential is almost constant on either side of the capacitor, and the electric field is almost zero.
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 101 ·
11K
20K
