| Thread Closed |
Pressure inside a chamber with a piston |
Share Thread |
| Aug1-07, 04:35 PM | #1 |
Pressure inside a chamber with a piston 1. The problem statement, all variables and given/known dataA vertical cylinder of cross-sectional area .07 m^2 is fitted with a tight-fitting, frictionless piston of mass 30 kg. The acceleration of gravity is 9.8 m/s^s. If there are 1 mol of an ideal gas in the cylinder at 395 K, find the pressure inside the cylinder. (Assume that the system is in equilibrium.) Answer in units of Pa. At what height will the piston be in equilibrium under its own weight? Answer in units of m. 2. Relevant equations PV=nRT P=Pressure V=Volume T=Temperature n=# of moles R (universal)= 8.31 J/mol/K 3. The attempt at a solution I have no idea... =( Volume isn't given.. and I don't know how to factor in the weight of the piston on the cylinder.. And please do not ask me to refer to my textbook, this is a summer assignment and we don't have any textbooks to use. |
| Aug1-07, 04:46 PM | #2 |
Recognitions:
AM |
| Aug1-07, 05:11 PM | #3 |
Okay well using what you said above.. (i did something similar to that in the first place but the answer was incorrect...)
[i submit the answers online for credit and i have 2 attempts of getting the right answer] f=ma so 30 kg * 9.8 m/s^s = 294 N of force from the piston working on the ideal gas and therefore 294 N of force from the ideal gas working on the piston 294 N/.07 m^s= 4200 Pa and somehow when i submit that it says its incorrect =( |
| Aug2-07, 11:42 AM | #4 |
Recognitions:
Pressure inside a chamber with a pistonAM |
| Aug2-07, 11:51 AM | #5 |
err.. how do i find that? =( |
| Aug2-07, 12:10 PM | #6 |
ok well i solved it but its still wrong.....
i got 1 atm as the average value of atmospheric pressure which is 101300 N/m^2 so i set up a proportion so it should be 7091 N/m^2 or 7091 Pa + the 4200 Pa from above which is 11291 Pa.. which is still wrong? :( |
| Aug3-07, 01:55 PM | #7 |
Recognitions:
AM |
| Thread Closed |
Similar discussions for: Pressure inside a chamber with a piston
| 120 GPa! Just what kind of a chamber can take that pressure? | General Engineering | 4 | ||
| Internal Energy: gas inside piston | Precalculus Mathematics Homework | 1 | ||
| Pressure in piston pump | Advanced Physics Homework | 3 | ||
| Pressure Chamber Help | Introductory Physics Homework | 1 | ||
| Pressure Chamber | Introductory Physics Homework | 0 | ||
