Here's a question on light ray optics and focal length.
The discussion revolves around the focal length of lenses in ray optics, particularly comparing the focal length of lenses to that of spherical mirrors. Participants explore the conditions under which the focal length can be considered as half the radius of curvature and the implications of lens material and thickness on this relationship.
  • One participant asserts that the focal length of a lens is not always half the radius of curvature, particularly when considering lenses made of different materials.
  • Another participant clarifies that the focal length of a spherical mirror is indeed half the radius of curvature, while the focal length of a lens depends on its refractive index and thickness.
  • Some participants emphasize that the Lensmaker's Formula provides a more accurate relationship for lenses than the simple f = R/2 equation.
  • There is a discussion about the prevalence of the f = R/2 formula in textbooks, with one participant recalling it from their physics class and various references.
  • Another participant challenges the validity of the f = R/2 formula for lenses and requests specific citations from textbooks to clarify its usage.
  • A participant acknowledges their confusion between mirrors and lenses, recognizing that the formula is not applicable to lenses.
  • One participant expresses gratitude for the clarification and reflects on their misunderstanding, while another reassures them that the discussion was valuable.
Participants do not reach a consensus on the applicability of the f = R/2 formula to lenses, with some arguing against it and others recalling its presence in educational materials. The discussion remains unresolved regarding the common misconceptions surrounding the focal lengths of lenses versus mirrors.
Participants note that the focal length of lenses is influenced by factors such as refractive index and lens thickness, which complicates the relationship compared to mirrors. There is also an acknowledgment of the potential for confusion between the two concepts in educational contexts.
Rainbow
Here's a question on ray optics.
We say that the focal length of a lens is half times the radius of curvature, right. Now, consider any lens(say convex), made of any material(say glass). Now a beam of light parallel to the principle axis, passes through the lens. All the rays in the beam will converge at a point, which we call the focus. For now, let us assume that the focal length of this particular lens is half time the radius of curvature of the lens. Now, take another lens whose structure is identical to that of the previous lens, i.e., it has the same radius of curvature and everything, the only difference being that this time the lens is made of a material that is denser than that of the previous lens. This time, if we pass a beam of light parallel to the principle axis through the lens, all the rays in the beam will converge at a different focus, with focal length shorter than that in case of the previous lens. So, we can see that, this time the focal length is not equal to half times the radius of curvature. This shows that saying that the focal length of a lens is half times the radius of curvature is not always true.
Please comment.
Science news on Phys.org
Actually, the focal length of a spherical mirror is half the radius of curvature of the mirror. The focal length of a lens of non-negligible thickness is indeed dependent on the refractive index of the material among other factors.
It doesn't matter. The situation that I have mentioned, is equally applicable to spherical lens.
Hootenanny said the equation you quoted is only for MIRRORS - you are correct that the focal length of any lens must depend on it's refractive index, but the focal length of a mirror doesn't.
The focal length of a thin spherical lens is given by the Lensmaker Formula; it's not simply R/2 as for a spherical mirror--it depends on both radii and the indices of refraction.
But then why in most places it is written that, f=R/2? As, you already mentioned that the f is given by the lens-maker's formula, and that it depends on both radii and the indices of refraction.
Where have you seen this?
Exactly. Which is certainly not f = R/2.
I have been taught this in my physics class. And I also found it many books like 'Fundamentals of Physics- by Halliday, Resnick and Walker', and my school textbook, and many other references.
I don't think so. Why don't you scan in the page in Halliday and Resnick where it says that, so we know what it is you're reading.
Or give us a short quotation from a specific book (authors and edition), along with the chapter and page number. If we're lucky, one of us will have the book and can look it up.
The introductory textbooks that I've seen all discuss spherical mirrors first, and give their focal length as [itex]f = - R / 2[/itex]. Then they move on to thin lenses, and introduce or derive the lensmaker's formula:
[tex]\frac{1}{f} = (n - 1) \left( \frac{1}{R_1} - \frac{1}{R_2} \right)[/tex]
(for a lens in vacuum, or to a good approximation, in air)
In my experience, it's common for students to glom onto the first formula they see for a certain quantity, and try to use it everwhere thereafter, even in situations where it doesn't apply.
You're correct. And I just realized that I am one of those students. The formula f=R/2 is for a spherical mirror and not a lens.
I'm sorry to waste your time for this stupid question. But thank you for having enough patience and reminding me of the fact.
I don't think it was a waste of time. True, as we suspected, you mixed up mirrors with lenses. But you showed excellent reasoning in your first post to prove that that formula didn't make sense for lenses. And now you've gotten it straight.
  • · Replies 17 ·
