What Are the Key Benefits and Processes of PEM Fuel Cells?
The discussion revolves around the functioning and implications of Proton Exchange Membrane (PEM) fuel cells, including their processes, benefits, and potential environmental impacts. Participants explore both technical aspects and broader implications of fuel cell technology.
  • Some participants describe the process of PEM fuel cells, noting the role of the proton exchange membrane and the reaction between hydrogen and oxygen to produce water.
  • Questions arise regarding the necessity of combining hydrogen with oxygen, with some suggesting that it is essential for energy production.
  • Concerns are expressed about the practicality of reusing hydrogen and the implications of water emissions on the environment.
  • Participants discuss the potential for future technology to convert water back into hydrogen, with differing views on the feasibility and motivations behind such developments.
  • There is a query about the effects of increased water vapor in the atmosphere if all car emissions were water, with predictions of potential health impacts.
  • Technical questions are raised about the behavior of electrons and protons in the fuel cell, including why electrons cannot travel through the membrane and why protons move towards the positively charged electrode.
Participants express a range of views, with no clear consensus on several points, including the practicality of hydrogen reuse, the environmental implications of water emissions, and the technical workings of the fuel cell components.
Some statements reflect assumptions about the behavior of electrons and protons, and there are unresolved questions regarding the charge states of electrodes and the implications of water emissions.
This discussion may be of interest to individuals exploring fuel cell technology, environmental science, and those seeking clarification on the technical workings of PEM fuel cells.
Alex
Being fairly new to the whole fuel cell thing (or at least how it works), I have a couple questions.
I have learned so far that Proton Exchange Membrane (PEM) fuel cells work using the following device and process:
The proton exchange membrane is a thin plastic sheet that allows hydrogen ions to pass through it. The membrane is coated on both sides with highly dispersed metal alloy particles (mostly platinum) that are active catalysts. The electrolyte used is a solid organic polymer poly-perflourosulfonic acid. The solid electrolyte is an advantage because it reduces corrosion and management problems. Hydrogen is fed to the anode side of the fuel cell where the catalyst encourages the hydrogen atoms to release electrons and become hydrogen ions (protons). The electrons travel in the form of an electric current that can be utilized before it returns to the cathode side of the fuel cell where oxygen has been fed. At the same time, the protons diffuse through the membrane (electrolyte) to the cathode, where the hydrogen atom is recombined and reacted with oxygen to produce water, thus completing the overall process.
Why must the hydrogen be combined with oxygen at the end of the process? Why can't you recycle the hydrogen and do the process over again?
*http://www.fuelcells.org/fctypes.htm#proton
It is probably better that the used hydrogen reacts with water to form H2O, because as mmwave said, it is probably too impractical to reuse the hydrogen.
H2O emissions are generally a lot better to the environment than CO2 and other hydrocarbons :smile:
Quick clarification here: its not a matter of practicality, combining hydrogen with oxygen is how you get the energy - its the whole point of having a fuel cell.
...until you factor in where the energy required to make the hydrogen came from, of course.
Hmm I must have misunderstood, then. I was thinking that the hydrogen broke up into an electron and a proton, with the proton traveling through the proton exchange membrane and the electron going through a separate wire. I assumed that the electron could simply combine with the h again and the process could be repeated.
So in order for the hydrogen proton and electron to recombine, they must combine with the O2 to form water?
russ_watters said:
Quick clarification here: its not a matter of practicality, combining hydrogen with oxygen is how you get the energy - its the whole point of having a fuel cell. ...until you factor in where the energy required to make the hydrogen came from, of course.
So the whole process could not occur without the water in the cathode. I see now. Doh! :biggrin:
Thanks everyone.
The force propelling the proton through the membrane is the same force propelling the electron through the wire. This is almost exactly the same as how any other battery works: ions flow one direction through the battery and electrons flow the other direction through the wire, meeting back in the battery.
Essentially yes.
It could also be so that the consumer will buy more hydrogen. This hydrogen car is going to be just like a gasoline car. Big, bulky, amp-consuming machines are going to be needed in order to take the water and convert it into hydrogen, so that we the people may buy it for $5.00 a gallon. Of course, with proper research one day we might be able to make a small enough water to hydrogen converter, to where it could fit in the hydrogen car, and we can simply fill our cars up with free water, but they won't let that research happen.
Not true. There is no real evidence that industry has stymied research in any way. In fact, both government and industry have worked hard for innovations in new fuel systems.
I'm opening a parenthesis here. If all present car emissions were H20 instead of CO etc. wouldn't the humidity considerably rise in some regions? Are people starting to forecast what are the consequences of this or is it still too early for serious thought? I predict some new health problems.
An electrolysis machine can be made as big or small as you want it - the problem is energy. And no, conspiracy theory has nothing to do with it: just the laws of science.
Car emissions are already mostly water and water already makes up a much larger fraction of our air than CO2 (in the summer and in temperate climates). More water in the air just means more fog and more rain (but an insignificant amount more) - the cycle is already closed. Not a big deal.
Nonsense.
Water is not a fuel. If you're going to use that idea, you need a supply of fuel onboard the car. (Batteries anyone?)
Pedals. We're all too fat, and all too fast.
Electrons and pem
Physics cw and my basic understanding at stake here!
please can someone explained to me why electrons are unable to travel through the menbrane and are forced to travel around creating an electrical circuit?
Ostensibly, the electric resistance of the conductor is less than the resistance through the membrane, and the voltage is such to attract the electrons through the conductor to the load.
Protons
Thank you for your reply, kind of understand and i was just also wondering, why the protons travel through the membrane at all, when they are positively charged and yet on the other side of the membrane is another positively charged electrode, so why would they be attracted this way ? any wesites that you think i wuld find useful would be very much appreiciated. Because i have found most to be confusing because they seem to say that the anode can be negatively charged, can this happen ? i need help! :)
15K
