Calculating Final Velocity of an Object with Power Input
The discussion revolves around calculating the final velocity of an object under constant power input, focusing on the relationship between mass, power, and distance traveled. The original poster presents a problem involving kinetic energy and power, aiming to derive a formula for final velocity based on given parameters.
  • Participants explore the derivation of velocity as a function of energy and time, questioning the accuracy of calculations and the placement of variables in equations. There is also a discussion on the implications of constant power input on acceleration, particularly in contexts like a rocket in space.
Some participants have identified potential calculation errors in the original poster's work, particularly regarding the placement of mass in the equations. There is an ongoing examination of the implications of constant power on motion, with participants seeking clarification on the relationship between power, velocity, and acceleration.
Participants are navigating through assumptions about the effects of constant power input on an object's motion, particularly in scenarios where external factors may influence the outcome, such as in space. The discussion reflects a mix of theoretical exploration and practical application of physics concepts.
HalfThere
An object of mass M begins with a velocity of 0 m/s at a point. A power input of P watts goes directly to kinetic energy until the object has traveled a distance of X meters. What is the final velocity of the object?
So, we have constant variables
M = mass
X = distance that power will be input
P = power level
And also
V = final velocity, after traveling distance X (to be solved)
E = 1/2MV[tex]^{2}[/tex]
X = [tex]\int[/tex]V(t) dt - V(t) is V as a function of time.
E = P*t
Find V as a function of E (easy)
V = [tex]\sqrt{2E}[/tex]/M
Find V as a funciton of time t (use equation)
V = [tex]\sqrt{2P*t}[/tex]/M
Now take the equation for X
And Find X as a function of t directly, knowing the V(t) function
X = [tex]\int[/tex][tex]\sqrt{2P*t}[/tex]/M dt Edit: Should be, and was calculated as ([tex]\int[/tex] [tex]\sqrt{2P*t}[/tex] dt)/M
Integrate (remember that sqrt(2P) is a constant)
X(t) = (2/3)*[tex]\sqrt{2P}[/tex]*t[tex]^{3/2}[/tex]/M
Now change to t in terms of X
t(X) = ((3/2)/[tex]\sqrt{2P}[/tex]*M*X)[tex]^{2/3}[/tex]
And finally slide that into the V(t) equation
V(X) = [tex]\sqrt{2P}[/tex]*((3/2)/[tex]\sqrt{2P}[/tex]*M*X)[tex]^{1/3}[/tex]/M
Simplify (whew!)
V(X) = 3[tex]^{1/3}[/tex]*2[tex]^{-1/6}[/tex]*P[tex]^{1/3}[/tex]*X[tex]^{1/3}[/tex]*M[tex]^{-2/3}[/tex]
So, V correlates directly with the cube root of X, the cube root of P, and M^(-2/3), with a weird constant.
Am I right? Am I not? If not, where did I go wrong?
Your general solution is fine, but I think you made some calculation errors... your m should be under the square root... so that affects your final exponent on m... also I'm getting that the 2 cancels out (ie the power of 2 is 0)...
I'm getting: [tex]3^{1/3}*p^{1/3}*x^{1/3}*m^{-1/3}[/tex] as the final velocity. Though I may have screwed up...
Which specific step does the miscalculation occur? I can't quite see what you mean.
Also, a more general question about energy: What will a constant power input do to something with a velocity with no immediate context, like a rocket in space?
On the one hand, I think acceleration should remain constant, because it's change in momentum is relative only to itself, but on the other hand, a constant rate of fuel consumption should mean a a constant power input. The two don't seem to be compatible. What gives?
X(t) = (2/3)*LaTeX graphic is being generated. Reload this page in a moment.*tLaTeX graphic is being generated. Reload this page in a moment./M
t(X) = ((3/2)/LaTeX graphic is being generated. Reload this page in a moment.*M*X)LaTeX graphic is being generated. Reload this page in a moment.here?
edit: the step where u isolated t.
I see where I went wrong with the 2^(-1/6), it should just be 3^(1/3) for the constant, but I still don't see the problem with the M. It was transformed from M to M^(2/3), then square rooted to M^(1/3), which was over M, which is M^(-2/3).
Here is the mistake... the M should be under the square root.
Ah, you're indeed right. I see now. And it makes sense if you look at units too.
Okay, Thanks learningphysics!
Acceleration isn't constant for constant power...
you're welcome.
Can anyone answer the third post of the topic, where I ask about conservation of momentum V. conservation of energy in the case of the rocket?
  • · Replies 25 ·
