Increase Velocity of Mass on String: Analyzing Kinetic & Potential Energy
The discussion centers on the relationship between kinetic and potential energy in a mass rotating on a string. When the speed of the mass is increased through manual manipulation, the kinetic energy rises due to the work done by the hand. The participants clarify that the increase in potential energy is not a direct result of kinetic energy decrease but rather from the work performed. Additionally, the impact of a charged mass moving in a vertical magnetic field is introduced, suggesting that tension in the string increases, leading to a rise in potential energy.
  • Understanding of kinetic energy and potential energy concepts
  • Familiarity with rotational motion principles
  • Basic knowledge of forces and work in physics
  • Awareness of electromagnetic effects on charged particles
  • Study the principles of work-energy theorem in physics
  • Explore the effects of magnetic fields on charged particles
  • Learn about the dynamics of rotational motion and tension in strings
  • Investigate the relationship between kinetic energy and potential energy in various systems
Physics students, educators, and anyone interested in understanding the dynamics of energy transformations in mechanical systems.
menager31
We've got some small mass on the string which is in rotatory movement in horizontal plane. let,s say that the velocity is v and the radius is r. Let's increase the speed of the mass by 'doing some movements with our hand'( we hold the string).
Now the potential energy is greater than it was before. So the increment of potential energy is from the decrease of the kinematic energy? Or it's from the work which was made by our hand?
Why do you say the potential energy is greater? If you increase the speed of the mass by 'doing some movements with our hand' then, since you have increased the speed, you have increased the kinetic energy, not the potential energy. And, yes, that increase is from the work done by your hand.
ok, and what if the mass has got a charge and is moving in vertical magnetic field? the tension of the string increases and the mass goes higher. From what is the increment of the potential energy?(from the kinematic!?)
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 16 ·
