Find Critical Points of dx/dt and dy/dt Equations
The critical points of the differential equations \(\frac{dx}{dt} = 1 - xy\) and \(\frac{dy}{dt} = x - y^3\) are determined by setting both equations to zero. The solutions yield potential critical points at (1, 1), (1, -1), (-1, 1), and (-1, -1). However, only (1, 1) and (-1, -1) are valid critical points, as (1, -1) and (-1, 1) do not satisfy the original equations simultaneously. This distinction is crucial for accurately identifying critical points in dynamical systems.
  • Understanding of differential equations
  • Familiarity with critical points in dynamical systems
  • Knowledge of algebraic manipulation and solving equations
  • Basic concepts of phase plane analysis
  • Study the method of finding critical points in nonlinear differential equations
  • Learn about stability analysis of critical points in dynamical systems
  • Explore phase portraits and direction fields for visualizing solutions
  • Investigate the use of Jacobian matrices for local stability analysis
Students studying differential equations, mathematicians focusing on dynamical systems, and educators teaching critical point analysis in mathematical modeling.
EugP
Find all the critical points:
[tex]\frac{dx}{dt} = 1 - xy[/tex]
[tex]\frac{dy}{dt} = x - y^3[/tex]
[tex]\frac{dx}{dt} = 0[/tex]
[tex]\frac{dy}{dt} = 0[/tex]
Here's what I did:
[tex]1 - xy= 0[/tex] ... [tex]x - y^3 = 0[/tex]
[tex]1 - xy= 0[/tex] ... [tex]x = y^3[/tex]
[tex]1 - y^4= 0[/tex] ... [tex]x = y^3[/tex]
[tex]y= 1, -1[/tex] ... [tex]x = y^3[/tex]
[tex]y= 1, -1[/tex] ... [tex]x = 1, -1[/tex]
So the critical points are:
[tex](1, 1) (1, -1) (-1, 1) (-1, -1)[/tex]
But in the book the answer is only:
[tex](1, 1) (-1, -1)[/tex]
Can someone explain to me why?
It doesn't really matter, but are those caculated from a given function or were you give the "direction field"?
Here's what I did:
I find your way of writing this a bit peculiar! You know that dx/dt= 1- xy= 0 and dy/dt= x- y3= 0. That's your first line. The second line repeats the first equation and solves the second for x: x= y3.
In the third line you replace the x in the first equation by y3, from the second equation, and have 1- y4= 0. That has the two (real) solutions y= 1 and y= -1. If y= 1, then the first equation becomes 1- x= 0 so x= 1: a critical point is (1,1). If y= -1 then the first equation become 1+ x= 0 so x= -1: a critical point is (-1, -1).
Because you get x= 1 only when y= 1, not when y=-1. Similarly, x= -1 is correct only when y= -1. You are looking for critical points, not just values of x and y that you then combine willy-nilly.
Oh now I understand. Thanks a lot!
  • · Replies 27 ·
