Prove Integral f&g Defined in R: Find Derivative
  • Thread starter Thread starter daniel_i_l
    Integral
The discussion centers on proving the definitions and derivatives of the functions F(x) and G(x) based on the functions f and g. The function f is defined as f(x) = 1/((ln(x+1))^2 + 1) for x > -1 and f(-1) = 0. The integral F(x) = ∫(0 to x^2 + 2x) f(t) dt is confirmed to be defined for all x in R, with its derivative calculated as F'(x) = (2x + 2)/((ln(x^2 + 2x + 1))^2 + 1). The function g is defined similarly, and it is established that G(x) = ∫(0 to x^2 + 2x) g(t) dt is also defined for all x > -1, sharing the same derivative as F(x).
  • Understanding of integral calculus, specifically the Fundamental Theorem of Calculus.
  • Knowledge of continuity and differentiability of functions.
  • Familiarity with the chain rule for differentiation.
  • Basic logarithmic functions and their properties.
  • Study the Fundamental Theorem of Calculus in depth.
  • Explore continuity and differentiability in more complex functions.
  • Practice applying the chain rule in various differentiation problems.
  • Investigate the properties of logarithmic functions and their derivatives.
Students studying calculus, particularly those focusing on integrals and derivatives, as well as educators seeking to clarify concepts related to function continuity and differentiability.
daniel_i_l
f is a function defined as: for all x>-1 f(x) = 1/((ln(x+1))^2 + 1) and for x=-1 f(x)=0.
a) Prove that [tex]F(x) = \int^{x^2 + 2x}_{0} f(t)dt[/tex] is defined in R and has a derivative there. Find the derivative.
b) g is defined as: for all x>-1 g(x) = f(x) and for x=-1 g(x) = -1.
Is [tex]G(x) = \int^{x^2 + 2x}_{0} g(t)dt[/tex] defined in R? Does it have a derivative there?
a)first I proved that f is continues for all x>=-1 Then since x^2+2x>0 for all x in R F(x) is defined and it's derivative is easy to get with the chain rule. I got:
F'(x) = (2x+2)/((ln(x^2 + 2x +1))^2 + 1)
b)Since g differs from f in only one point F(x) = G(x) and so G is defined and has a derivative for all x in R.
Is that right? I'm mostly worried about (b).
Thanks.
Looks good to me :) Other than the small error than G is defined and has a derivative for all x > -1, not all real values.
In (2), it helps to notice, as you said for (1), that x2+ 2x is never negative: the interval of integration, 0 to x2+ 2x, does not contain -1 and so what happens there is irrelevant.
  • · Replies 105 ·
13K
  • · Replies 23 ·
