Let E be an algebraic over F, F is perfect. Show that E is perfect
  • Context: Graduate
  • Thread starter Thread starter barbiemathgurl
The discussion revolves around proving that if \( E \) is an algebraic extension of a perfect field \( F \), then \( E \) itself is perfect. The scope includes theoretical aspects of field extensions and properties of algebraic and perfect fields.
  • Some participants clarify that "perfect" means all algebraic extensions are separable.
  • One participant suggests examining the relationship between the irreducible polynomial of an element over the base field and over a larger field.
  • A participant proposes a series of steps to show that the irreducible polynomial of an element in \( E \) has zeros of multiplicity 1, hinting at the connection to the irreducible polynomial over \( F \).
  • There is a question regarding the notation \( \text{irr} <\alpha, E> \), with one participant interpreting it as the monic irreducible polynomial containing \( \alpha \) as a zero, while another expresses confusion about its meaning.
Participants do not reach a consensus on the proof or the notation used, indicating that multiple interpretations and approaches exist within the discussion.
The discussion includes unresolved questions about the notation and the implications of the definitions of perfect fields and algebraic extensions.
barbiemathgurl
let E be an algebraic over F where F is perfect. Show that E is perfect. :rolleyes:
Well, what have you tried? Our purpose here is to help you work through a problem, not to be an answer book!
what doies perfect mean? all algebvraic extensions are separable? sounds trivial from the definitions doesn't it? have you thought about it?
if so, and it still eludes you, think abiout the relation between the irreducible polynomial for a given element over a base field as opposed to over a larger field.
@mathwonk: Yes "perfect" means all extensions are seperable.
@barbie: Do the following
1)Let [tex]K/E<\infty[/tex].
2)Let [tex]\alpha \in E[/tex]
3)Show [tex]\mbox{irr} \left< \alpha, E \right>[/tex] has zeros of multiplicity 1 (Hint: Show that [tex]\mbox{irr}\left< \alpha, E \right> | \mbox{irr} \left< \alpha, F \right>[/tex]*
*)If K algebraic over E algebraic over F then K algebraic over F.
Just out of interest: What does the notation irr<a,E> mean?
I though maybe it was a notation for the minimal polynomial of a over E, but as a was in E that doesn't make much sense your 3 wouldn't make much sense.
It is the monic irreducible polynomial such that contains "a" as a zero. This notation is non-standard, but saves space which I have seen in one book.
  • · Replies 19 ·
  • · Replies 19 ·
