| Thread Closed |
Position Vectors, Velocity Vectors, and Acceleration Vectors |
Share Thread | Thread Tools |
| Aug12-07, 05:37 PM | #1 |
The coordinates of an object moving in the xy plane vary with time according to the equations x = -(5.00 m)sin(wt) and y = (4.00 m) - (5.00 m)cos(wt), where w is a constant and t is in seconds. (a) Determine the components of velocity and components of acceleration at t = 0. (b) Write expressions for the position vector, the velocity vector, and the acceleration vector at any time t > 0. (c) Describe the path of the object in an xy plot.
(a) When time is zero, the positions of x and y are 0 and 4, respectively. I am wondering how I can determine a velocity of a vertical line. I don't think it is zero, as that would be a horizontal line, and to have no slope would mean that there isn't a velocity. Where there is no velocity, there is no acceleration, so to find the components would be impossible. (b) My problem here is that there are two different equations dealing with the components. It is not an independent variable as x and the dependent variable as y. However, if I squared both equations, added them, and then took the square root (like find the length of the hypotenuse), would that be an equation for the position? And since it says at any time greater than zero, am I to take the derivative of such equation to get the velocity, and again for the acceleration? (c) I...really don't know what to do with this part, but I'm positive that this has something to do with part (b) (...duh), which, well, I'm not getting either. I think I'm over-complicating things, especially in part (b), because nothing in this portion of my chapter (...the beginning) did anything this weird. Help? |
| Aug12-07, 07:07 PM | #2 |
[tex]{v}_{x}=\frac{d}{d\,t}\,{s}_{x}[/tex] [tex]{v}_{y}=\frac{d}{d\,t}\,{s}_{y}[/tex] [tex]{a}_{y}=\frac{d}{d\,t}\,{v}_{y}[/tex] b) it's asking for the position vector... and so use those parametric equations. c) I would say it has nothing to do with b. just eliminate t, and combine those two equations so as to make y>>x |
| Feb8-09, 08:41 PM | #3 |
I have a big problem here, i dont understand a word, can someone explain it from the begining ?
| Feb9-09, 08:45 PM | #4 |
Recognitions:
Position Vectors, Velocity Vectors, and Acceleration VectorsThis is a textbook problem. Start from your book definitions (or read rootx reply) of velocity, and acceleration. Remember that because this is a 2D movement, your vectors must account for both x and y components. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Position Vectors, Velocity Vectors, and Acceleration Vectors
| velocity and acceleration vectors | Introductory Physics Homework | 2 | ||
| PROOF: Independent vectors and spanning vectors | Linear & Abstract Algebra | 8 | ||
| Vectors of position, velocity, and acceleration. | Introductory Physics Homework | 2 | ||
| Acceleration/Velocity vectors question | Introductory Physics Homework | 2 | ||
| Position vectors | General Math | 3 | ||
