unica
- 26
if you open an icebox's door which is in a somewhat large,isolated space,the temperature of the space will become high or low?why?
The discussion revolves around the effects of opening an icebox (or refrigerator) in an isolated space on the temperature of that space. Participants explore the thermodynamic principles involved, including the zeroth and first laws of thermodynamics, while addressing various assumptions and variables that could influence the outcome.
Participants express multiple competing views on the effects of opening the icebox, with no consensus reached on the overall impact on temperature. The discussion remains unresolved, with various assumptions and interpretations presented.
Participants highlight the importance of initial temperature conditions and the nature of the icebox or refrigerator being discussed, indicating that these factors significantly influence the outcome. There is also mention of potential misunderstandings due to the phrasing of the question.
mgb_phys said:Danger - it might not be homework, it might GW's new science advisor working on a solution to global warming.
i.mehrzad said:Why do we need any variables.
According to the zeroth law of thermodynamics heat will be transferred from the surrounding to the system. Until the two that is the surrondings and the system reach equilibrium.
Why is there any need for variables to be supplied. I don't know. Please could you correct me if i am wrong.
Danger said:To start with, we don't know the initial temperatures of the interior and exterior of the refrigerator. It's entirely possible that the interior is actually warmer.
unica said:oh...,my original mean focuses on the quantity of heat between the icebox to surroundings and the icebox self-generated by cooling the inner space of it. which is larger between this two quantity of heat? and I am under the assumption that the fridge is a normal, powered fridge, that gets opened in standard room-temperature conditions.i think it should be refer to the 1st and 2nd laws of thermodynamics
Danger said:Given that presumption, you're totally correct. I just prefer not to assume anything.
unica said:this problem is based on the naive problem "if i open an icebox's door, can i cool down the temperature of my house?"
maybe i can illustrate this problem in this way:i only care about two factors in this problem,one is that the inner space of the icebox can transport heat to the surroundings so as to lower the temperature of surroundings,the other is that the icebox would generate heat due to lowering the temperature of the inner space.you can feel the heat on the side surface of the icebox, right?and this heat can heighten the temperature of surroundings.so eventually what is the temperature of the surroundings?does it a little higher or lower than the original one?
Pythagorean said:I encourage you to!
Assumptions are helpful, as long as you declare them and remain aware they are assumptions. This is how theoretical science develops. It's ok to be wrong as long as you can acknowledge it.
HallsofIvy said:A varient problem is this: take a refrigerator that is already at room temperature into a room, plug it in and turn it on (with the door open). what will happen to the temperature in the room?
Danger said:Usually, it's a communications problem based upon either the age of the correspondent or a lack of English fluency
