Heat generated by friction force
The discussion focuses on calculating the heat generated by friction between a circular disk and a plate during rotation. Key factors include the velocity of the plate, the reaction force, and the coefficient of friction, which can be expressed through the formula F = coefficient of friction x Reaction force. Tommo suggests using the motor power required to move the discs under load as a basis for estimating heat generation, acknowledging that not all power contributes to temperature rise due to energy losses in other forms.
  • Understanding of friction force calculations
  • Knowledge of power and energy conversion principles
  • Familiarity with mechanical systems involving rotating components
  • Basic thermodynamics related to heat generation
  • Research methods for calculating heat generation in rotating systems
  • Explore the relationship between power, heat, and temperature rise in mechanical systems
  • Learn about energy loss mechanisms in frictional contacts
  • Investigate the impact of material properties on friction and heat generation
Mechanical engineers, design engineers, and anyone involved in the analysis of friction in rotating machinery will benefit from this discussion.
Prune_man
Hi guys,
I have a circular disk on the end of a rotating shaft. The disk is pressed into another plate and is rubbing together making friction. I need to know how much heat is going to be generated by the friction.
I think it is a function of the velocity of the plate, the reaction force and the coefficient of friction but I'm not sure.
I know that the Friction force, F=coefficient of friction x Reaction force.
I'm not sure how to change this into a temperature rise or even a heat rise.
Thanks guys
Tommo
The quickest way would be to take the motor power required to move the discs under load and assume that all of that power goes into your heat rise since power is energy per unit time. Of course, not all of that power will go into the temperature rise between the plates. Some of it will go into deflections of the plates and shafts, noise and heat in other areas. It should be a pretty good estimate of what your best condition would be (if you are interested in getting all of the heat possible).
  • · Replies 45 ·
