Vectors of position, velocity, and acceleration.
The discussion focuses on calculating the vector position, velocity, and speed of a particle with an acceleration of a = 3.00j m/s² and an initial velocity of v[initial] = 500i m/s. The position vector at any time t is determined to be r[f] = (500t)i + (1.5(t²))j, while the velocity vector is v = 500i + (3.00t)j. At t = 2.00s, the coordinates are found to be x = 1000 and y = 3, with a speed of 500.036 m/s. The discussion clarifies the distinction between velocity as a vector and speed as a scalar.
  • Understanding of vector components in physics
  • Familiarity with kinematic equations
  • Basic knowledge of calculus for motion analysis
  • Ability to differentiate between speed and velocity
  • Study kinematic equations in detail, focusing on vector components
  • Learn about the implications of acceleration on motion in two dimensions
  • Explore the concept of vector magnitude and its applications in physics
  • Investigate the relationship between speed and velocity in various contexts
Students and professionals in physics, particularly those studying mechanics, as well as educators looking to clarify concepts of motion and vector analysis.
niyati
A particle initially located at the origin has an acceleration of a = 3.00j m/s^2 and an initial velocity of v[initial] = 500i m/s. Find (a) the vector position and velocity at any time t and (b) the coordinates and speed of the particle at t = 2.00s.
(a) I looked at the examples given in the chapter, and to find the velocity at any time seemed to be the final velocity, which was found through the equation of v[f] = v + at. That means that the final velocity is equal to it's components added, and the same goes for the initial velocity and acceleration. So:
ax = 0 ay = 3.00 vx = 500 vy = 0
Working each component separately, I got 500i + (3.00t)j.
For the position, I, again, separately worked each component, using the equation r[f] + r + vt + .5at^2.
The initial position is (0,0), so my answer is:
r[f] = (500t)i + (1.5(t^2))j
(b) To find the coordinates of position, I took my last equation from above, and broke it down into it's components, where x[f] = x + vx + .5(ax)(t^2) and y[f] = y + vy + .5(ay)(t^2), all while plugging in 2 for time. x = 1000 and y = 3.
For speed, my previous findings of 500i + (3.00t)j, I got 500i + 6.00j when plugging in 2. That would be the velocity, and taking the absolute value would equal speed. But, I don't think speed is in it's components, and so I drew the hypotenuse of the triangle the vectors formed, and got 500.036 m/s.
...for some reason, I'm not sure if that is right. I kind of guess on taking the hypotenuse, but I don't know if I should do that, if I've already plugged into an equation specifically for velocity. What I'm wondering seems stupid, but, well, X/
Thank you in advance.
(a) is correct
for (b), y=3 is incorrect, check your calculations
the speed of 500.036 m/s is correct. Remember, velocity is a vector, so it must have components. Speed is a scalar, hence doesn't have components. It is the magnitude of velocity
ah! I forgot to square the time before multiplying it by .5 and the vertical component of acceleration.
Thank you for your help! :D
