Is My Calculation for Terminal Speed of a Falling Conducting Loop Correct?
  • Thread starter Thread starter edtman
    Law Lenz's law
The discussion centers on calculating the terminal speed of a falling rectangular conducting loop in a magnetic field, as posed in HRW CH31 #28P. The key equation derived is the balance between gravitational force and the Lorentz force, expressed as F(Lorentz) = mg. The induced EMF is calculated using magnetic flux principles, leading to the relationship EMF = aBLt/R. The conclusion emphasizes the importance of recognizing that acceleration is not constant due to the increasing magnetic force as velocity increases, ultimately affecting the terminal velocity calculation.
  • Understanding of electromagnetic induction and Faraday's law
  • Familiarity with the concepts of terminal velocity and forces in motion
  • Knowledge of calculus, particularly integration and differentiation
  • Basic principles of magnetic fields and Lorentz force
  • Study the principles of electromagnetic induction in depth
  • Learn about the dynamics of terminal velocity in different mediums
  • Explore the relationship between induced EMF and current in circuits
  • Investigate the effects of varying forces on motion using calculus
Physics students, educators, and engineers interested in electromagnetism, dynamics of conducting materials, and advanced mechanics will benefit from this discussion.
edtman
Please look for flaws in my reasoning, any help would be appreciated.
Question:
HRW CH31 #28P(if you have the book handy)
A long rectangular conducting loop of width L, resistance R, and mass m, is hung in a horizontal, uniform magnetic field B that is directed into the page and exists only above line aa. The loop is then dropped; during its fall, it accelerates until it reaches a certain terminal speed. Ignoring air resistance, what is this terminal speed?
Answer:
For the falling loop to reach a constant terminal speed the force of gravity pulling it downward must be canceled by a Lorentz Force pullint it upward
F(Lorentz)=mg eqn 1
To find F(L) we must first find the induce EMF, then the induced current and finally use this to determine F(L).
Magnetic Flux:(MF)=Integral[B*dot*dA] Let x equal vertical length of loop in B field.
(MF)=B*L*x
EMF=d/dt*(MF)=d/dt*BLX=BL*dx/dt=BLv
Now taking the derivative of both sides with respect to t:
d/dt*EMF=dv/dt*BL=abL
intergrate both sides with respect to t:
Integral[d/dt*EMF*dt=aBL*Integral[dt]
EMF=aBLt
This sounds reasonable because EMF should be increasing with time since change of flux is increasing with time.
Now in terms of current:
i=EMF/R=abLt/R
and Force:
F=aB^2*L^2*t/R
Subbing g for a and rewriting eqn 1 from way above:
mg=gB^2*L^2*t/R
solving for t:
t=MR/(M^2*L^2)
Using kinematics equation:
V(terminal)=g*t
Sound Plausible? Thanks for your time.
Here, I think, is a problem:
EMF=aBLt
(You could have saved yourself some time by simply claiming that v = at, which in effect is what you have done.)
Problem is you are assuming that a is constant. I think you will agree that this is the case here. The magnetic force exerted on the coil is increasing as v increases.
In fact, if you just remember that you are looking for a terminal velocity, it will be obvious that ai=g, and af=0.
Ahhh :rolleyes: , thanks for pointing that out; I sensed a bit of redundancy(sp?), but wasn't sure enough to simplify. Then again, I can use the practice showing relationships via Calculus.
