Elevator Torque and Angular Momentum
The discussion centers on calculating the necessary counterweight for a 22,500N elevator to achieve an upward acceleration of 1.5 m/s² over a distance of 6.75 m in 3 seconds. The mass of the pulley is 875 kg with a diameter of 1.50 m, leading to a moment of inertia of 246.1 kg·m². The correct counterweight mass is determined to be 31,600 N, with tensions in the cable calculated as 26,000 N and 26,700 N on either side of the pulley, respectively. The initial calculations presented were incorrect due to misinterpretation of the forces acting on the elevator.
  • Understanding of Newton's second law of motion
  • Familiarity with torque and angular momentum concepts
  • Knowledge of moment of inertia calculations
  • Basic proficiency in kinematic equations
  • Study the principles of torque and angular acceleration in rotational dynamics
  • Learn how to apply Newton's laws to systems involving pulleys
  • Explore the derivation and application of moment of inertia for different shapes
  • Investigate kinematic equations for uniformly accelerated motion
Physics students, mechanical engineers, and anyone involved in the design of elevator systems or studying dynamics and kinematics in engineering contexts.
usnberry
A 22,500N elevator is to be accelerated upward by connecting to it a counterweight using a light cable passing over a solid uniform disk-shaped pulley. There is no appreciable friction at the axle of the pulley, but its mass is 875kg and it is 1.50 m in diameter. (a) How heavy should the counterweight be so that it will accelerate the elevator upward through 6.75 m in the first 3.00 s, starting from rest? (b) Under these conditions, what is the tension in the cable on each side of the pulley?
I=1/2*875*.75[tex]^{2}[/tex]=246.1 kg*m[tex]^{2}[/tex]
a=(2*6.75)/(3[tex]^{2}[/tex])=1.5m/s[tex]^{2}[/tex] from x=(x[tex]_{i}[/tex])+(.5)(a)(t[tex]^{2}[/tex])
[tex]alpha[/tex] = a/r = 2 rad/s^2 from a = R * [tex]alpha[/tex]
[tex]\Sigma[/tex][tex]\tau[/tex]=I*a
So I get from this is that for the elevator to rise the 6.75 feet in 3.00 seconds the total torque must be 492.2 N*m.
T[tex]_{1}[/tex]=m[tex]_{elev}[/tex]*g-m[tex]_{elev}[/tex]*a
T[tex]_{2}[/tex]=m[tex]_{counter}[/tex]*g+m[tex]_{counter}[/tex]*a
From this I get T[tex]_{1}[/tex] = 19056 N
[tex]\Sigma[/tex][tex]\tau[/tex] = T[tex]_{1}[/tex]*r-T[tex]_{2}[/tex]*r
So...
T[tex]_{2}[/tex] = 18400 N
So should be...
m[tex]_{counter}[/tex] = 1628 kg * 9.8 = 1.6*10^4 N
Unfortunately, according to the book I am wrong on all three counts, the tensions and the mass. The answers are supposed to be 3.16*10^4 N mass counter, 2.60 * 10^4N Tension 1 and 2.67 * 10^4N for Tension 2.
Any help would be greatly appreciated. Thanks in advance.
The directions for your forces are wrong I think... the elevator is accelerating upward, so what's the sum of the forces in the vertical direction for the elevator?
Remember that a is upward for the elevator.
  • · Replies 17 ·
  • · Replies 19 ·
18K
