Gyroscope/bicycle wheel question
  • Context: Undergrad
  • Thread starter Thread starter Europeman
    Wheel
The discussion revolves around the behavior of a gyroscope or a spinning wheel when it is tilted, specifically focusing on the energy input required to achieve this tilt and the implications for angular momentum. Participants explore the concepts of work, energy transfer, and the dynamics of rotating systems, with references to real-world analogies like bicycle wheels and ship helms.
  • One participant questions where the energy goes when tilting a spinning wheel, suggesting that energy is added to the system.
  • Another participant argues that no work is done when tilting the wheel because the force applied is at right angles to the direction of movement, drawing an analogy to a truck moving on a horizontal road.
  • A different participant counters that the situation is not analogous to the truck, suggesting that the dynamics of a bicycle wheel or gyroscope are more complex.
  • One participant emphasizes that when applying forces to a gyroscope, the work done is zero due to the nature of the forces and displacements involved.
  • Another participant highlights that if a wheel is not rotating, applying a force does result in work being done, which adds kinetic energy to the wheel.
  • There is a mention of the importance of distinguishing between non-rotating and rotating systems, noting that the behavior of gyroscopes can lead to misunderstandings.
  • One participant reflects on the complexity of gyroscopes and the potential for misconceptions in their design and operation.
Participants express differing views on the nature of work done when tilting a gyroscope, with no consensus reached on whether energy is added to the system or where that energy goes. The discussion remains unresolved with multiple competing perspectives on the topic.
Some participants note that ignoring factors like friction can lead to different conclusions than those experienced in practical scenarios. The discussion also highlights the complexity of gyroscopic behavior and the potential for misunderstandings in its application.
Europeman
Hi there...
As English is not my native language I want to apologise up front for any mistakes.
I have tried asking my question in a local Dutch forum, but I have not received a satisfactory answer yet. So, I thought I will try internationally.
Imagine a fast spinning wheel, like in a gyroscope. Let's assume there's no friction of any kind, so if you let it it will keep spinning at the same speed.
Now you tilt the spinning wheel by 90 degrees. Of course it resists this movement (I think conservation of angular momentum is the right word?), but you don't allow it to move in any other way than the 90 degrees tilt that you intend.
To move the wheel this way you put in energy. You have to overcome the resistance all the way.
My question is: Where does this energy go?
I don't mean any heat resulting from friction. You put in energy, you add energy to the spinning-wheel-system, where does it go?
Does the speed (rate?) of spinning change? Decelerate? Accelerate?
I hope my question is clear, and I'm looking forward to any replies. Thank you.
You don't put in any energy. The movement is at right angles to the direction of the force, so scalar product of force . distance = 0.
If a truck is moving along a horizontal road, the weight of the truck doesn't do any work as the truck moves, for the same reason.
I'm having trouble posting a reply... I'll try again, hope I don't post double...
Aleph, you're right about the truck, but this is not a truck. Try it, with a bicycle wheel... Read about Gyroscopes, think about this toy, I think it's a Spin Top in English...
Eurpoeman, I've been designing and analysing rotating machinery for more than 30 years. I know what a gyroscope is and how it works.
Suppose your bike wheel is vertical, and you want to turn it so it is horizontal. You move one end of the axle up and the other end down. The forces you apply to stop the gyroscope effect are forwards and backwards, at right angles to the direction you move. The work done by the scalar product of the force and displacement vectors is zero.
Aleph, I never meant to question your knowledge, I just thought I failed to make my question clear to you. Thank you for your new reply.
I'm afraid I still don't understand though. What you say would mean that any two-handed action, rotating something with hands on opposite sides, would mean zero work. Like turning the helm wheel of a ship... An old ship, not "fly by wire" :)
No, if you turn the helm of a ship you apply a force tangential to the wheel. You move in the same direction as the force, not at right angles to it.
If the bike wheel is not rotating and you apply a force up on one side and down on the other, then you are doing work. You give the wheel some kinetic energy while it is turning.
To stop the axle changing direction, you have to apply a force in the opposite direction. After it has stopped, the total amount of work you did was zero. The work to start the wheel moving = - the amount of the work to stop it again. Once the axle is turning, if you apply no force it will keep turning at the same speed (Newton's Laws).
But if the wheel is rotating like a gyroscope and you apply a force up on one side of the axle and down on the other side, the axle will turn in the horizontal plane, not in the vertical plane. If you stop applying a force, the axle will immediately stop changing direction. You don't have to apply a force in the opposite direction to stop it.
For a non-rotating wheel, the angular acceleration of the axle is proportional to the torque you apply. For a rotating wheel (a gyroscope), the angular velocity of the axle is proportional to the torque. That's an important difference for understanding how gyroscopes behave.
When you ignore things like friction in a physics question you often get a different behaviour to what you feel in the 'real' world.
In physics you do no work by pushing a truck along a level surface, but you definitely feel something in your muscles.
Gyroscopes are complicated because of this. Many people spend their lives designing them - like AlephZero, but many more people spend their lives designing impossible machines because they misunderstood how they work.
Europeman said:
Hi there...
I think that's the problem---if you 'turn' the wheel (work), there will be friction at the axil/bearing, and that's where the 'energy' is lost.
  • · Replies 39 ·
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 42 ·
