| Thread Closed |
New Concept Engine |
Share Thread | Thread Tools |
| Aug30-07, 08:33 AM | #1 |
New Concept Engine
Hi! I have designed a new concept engine and hope that I can get some useful feedback.
http://www.geocities.com/rotarypulsejet . The design is quite radical and I would appreciate any comments that you might have. django |
| Aug30-07, 08:56 AM | #2 |
Recognitions:
Link does not work.
| Aug30-07, 09:02 AM | #3 |
Welcome to PF, Django.
It's impossible to tell from your picture just how much planning you've put into both the basic design and the necessary subsystems. The most obvious deficits are that you don't indicate how you'll deal with either ignition timing or air/fuel intake. I can foresee a lot of problems with this idea, but further discussion is warranted. edit: Hi, Fred. It worked fine for me the first time; now it's giving some sort of overload notice. The design basically involves a pair of tip-jets built into a rotating disk inside some sort of housing with 2 opposed exhaust ports. |
| Aug30-07, 09:04 AM | #4 |
Recognitions:
New Concept Engine
After two or three pages I got the message "The GeoCities web site you were trying to view has temporarily exceeded its data transfer limit. Please try again later."
Actually, I got bored waiting for the BMP on the front page to download and started viewing the other pages, so I never got to see the image on the front page. You might want to replace the BMP with a smaller JPG file, or something. It's not fair to comment on it before seeing all your descrption, so I won't - except to say the basic idea makes sense, though there may be some practical problems with it. |
| Aug30-07, 09:11 AM | #5 |
Recognitions:
I can tell you that I have experience dealing with this concept with one exception. The designs I have worked with were continuous burners, not pulse jets. However, I can tell you that there are indeed many pitfalls to this idea and depending on some of the constraints, i.e. rotational velocity and fuel flow, the basics in the design become very difficult. Like Aleph, I will await to see a cross section though before getting too much into it. |
| Aug30-07, 12:17 PM | #6 |
Looks like a Catherine Wheel to me.
How do you fuel it? How do you provide combustion air? How do you control it? |
| Aug30-07, 01:27 PM | #7 |
I have a bit of an idea of how the thing might actually work, but I wouldn't go so far as to call it a 'pulse jet'. It's more like a Wankel with the combustion chambers built into the rotor. In the design as shown, timing would be absolutely critical and the thing would be able to run at only one constant rpm value.
| Aug30-07, 03:31 PM | #8 |
Danger's comment:
| Aug30-07, 04:29 PM | #9 |
You're right about the Wankel, Django. I was just trying to help the others visualize it (I didn't realize at the time that your link was working again).
What I meant about the timing is that you have a very narrow window of time/angle when combustion can take place. That means that the rpm's have to be set so that each 'jet' fires exactly twice per revolution, when it's lined up with one of the exhaust ports, and it has to be a fast burn. I defer to Fred's expertise in the matter, but I think that it would be very difficult if not impossible to tune the pulse frequency that precisely. Pulse-jets ordinarily have a much higher 'duty-cycle'. |
| Aug30-07, 08:00 PM | #10 |
Hi! Danger, in practice the timing is not a problem at all, think about it, this engine is running in a perfect circle, not the extremely complicated lienar up and down motion of the IC piston engine, therefore grooves and cams placed on the inner surface of the rotor housing in which the rotor runs can interact with spring activated valve stems to open them at exactly the right moment. The calculations needed to do this accurately are simple. It is the ignition timing that is a little more complicated, if maximum power is to be extracted from the system, but with todays technology this can easily be solved.
I almost forgot, I have been meaning to do this for my last two posts but kept forgetting: __________________ |
| Aug30-07, 08:55 PM | #11 |
Okay, I'm getting a better idea of what you have in mind now. I just got hung up on the term 'pulse-jet' and thought that you're trying to harness a couple that work on the normal principle. Thinking of them more as 'on-demand jets' eliminates most of my objections. My main problem was simply that a regular pulse-jet spends just about equal amounts of time inhaling and exhaling, whereas yours will be 'coasting' for most of the cycle. It seems to me that you could get a much longer and more efficient burn time if you were to mill exhaust grooves around a lot more of the circumference rather than just have those two little ports.
You might also eliminate any other mechanical complications such as the cams and valves that you mentioned by simply drilling holes from the face rather than the rim of the rotor into the combustion chambers that will cyclically match up to intake ports in the case. The rotor would then in effect become its own rotary valve. It would be a lot simpler, and shouldn't have much different sealing issues than anything else. One issue which might cause an efficiency loss is the manner in which a pulse-jet (and maybe your design) breathes. The old buzz-bomb units, at least, were discovered to actually suck something like 80% of the fresh intake charge through the tailpipe rather than the valvebox. Your 'tailpipes' are sealed except for when they're lined up with the exhaust ports. |
| Aug31-07, 12:43 AM | #12 |
Comment by Danger
Kindly note the combustion chambers are equal in volume to the combustion chambers of an ordinary IC Piston engine, so what I have in effect done is take only the combustion chamber volume of an IC piston engine and used them as the jet pods (combustion chambers} of my design, the rest, the cylinder, pistons etc., have been discarded . Next these combustion chambers are supplied with compressed air at a pressure of 125 psi, in a fully sealed environment. That is from the compressed air tank, through the rotary union, through the passages in the rotor, where fuel is added ( again through a separate pipe in the rotary union) to the combustion chambers in an absolutely air-tight and pneumatically sealed environment, this compressed air/fuel mixture is then fed to the combustion chambers via an inlet poppet valve, which is one of the best air-tight seals going. A pressure of 125 psi works out to a compression ratio of 9:1. The inlet poppet valve is closed and the fuel ignited by a piezoelectric spark plug. The fuel/air mixture combusts and the volume and temperature rise accordingly, almost simultaneously a gate valve to the Convergent/Divergent (CDN) De Laval nozzle is opened and these hot gases escape at velocity providing the power for the engine in the same way that a rocket provides power. Notice that the engine is designed for efficiency, with only two pods there is no problem with cooling. Comment by Danger |
| Aug31-07, 01:33 AM | #13 |
Your post has given me much more to consider, since you've obviously looked into this a lot more thoroughly than your picture and initial description indicated. To start with, your combustion chambers are far bigger than was apparent, and there was no indication of a specific nozzle design in the illustration. Goodnight for now. |
| Aug31-07, 07:03 AM | #14 |
Recognitions:
I finally got to see the link. I didn't get a chance to read all of the presentation though. It's a sound concept. Of course, the devil is in the details. Have you got one of these running yet?
I have a few questions: - What is the expected operational angular velocity? - Do you have any data to back up the zero emissions claim? - In your section regarding the materials, you seem to concentrate on the melting point of steel. Are you aware of the rapid degradation of yield point as a function of elevated temperatures? - What fuel are you running on or plan on running on? |
| Aug31-07, 08:42 AM | #15 |
Thanks Fred a great post,
| Aug31-07, 09:24 AM | #16 |
Well, this is embarrassing.
Fred's comment about the 'presentation' prompted me to revisit the link. My monitor is fairly small, so I have to scroll around to see the whole picture. I had not, however, scrolled down far enough to see that there was more to it. Everything that I've said has been based purely upon the initial drawing. ![]() Now that I've discovered the textual part and started reading it, things are falling into place very nicely. Unfortunately, I might not have time to get into it very much today, and will be away for the weekend. I'm really looking forward to studying it in detail. |
| Aug31-07, 09:30 AM | #17 |
Hi Danger! I thought that you'd be gone for the next 72 hours. I am just posting to say that , now that I've explained most of my views I think I'd like to sit back and see what others have to say, good or bad. I feel like I' hogging the whole thread, comment- reply, comment-reply, which is not pleasant for anyone. So if you don't mind, from now on I'll just try and listen, if that's OK. django
| Thread Closed |
| Thread Tools | |
Similar Threads for: New Concept Engine
| Work Done By Engine/Heat Engine | Mechanical Engineering | 3 | ||
| Gasoline Engine Turbocharger Concept. | Mechanical Engineering | 4 | ||
