What is the area of a 7.000 μm thick leaf made of 7.000 oz of gold?
  • Thread starter Thread starter jjc39
    Density Homework
The discussion revolves around a problem involving the properties of gold, specifically calculating the area of a leaf made from a given mass of gold and its thickness, as well as the length of a cylindrical fiber made from the same mass. The subject area includes concepts from density, volume, and geometric relationships.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the relationship between mass, density, and volume, suggesting the use of equations to find the area and length based on given parameters. Questions arise regarding the interpretation of terms like "in terms of thickness and area."
The discussion is active, with participants exploring different interpretations of the problem. Some guidance has been offered regarding the use of density and volume equations, but there is no explicit consensus on the approach to take.
Participants note the importance of unit conversions and the fixed nature of the volume derived from the mass and density of gold. There is an emphasis on understanding the relationships between the geometric properties involved.
jjc39
Gold, which has a mass of 19.32 g for each cubic centimeter of volume, is the most ductile metal and can be pressed into a thin leaf or drawn out into a long fiber. (a) If a sample of gold with a mass of 7.000 oz, is pressed into a leaf of 7.000 μm thickness, what is the area (in m^2) of the leaf? (b) If, instead, the gold is drawn out into a cylindrical fiber of radius 2.400 μm, what is the length (in m) of the fiber?
I know its simple but I can't seem to know where to get started
Use the equation: density = mass/volume
For part a) what is the volume of this leaf in terms of thickness and area... use this along with the above equation to solve for area...
For part b) what is the volume in terms of radius and length... use this with the density equation to solve for height.
Be careful about units.
what do you mean by in terms of in terms of thickness and area
mass is given, density is given. You know the volume then. This volume is fixed. So, get your area (first case) and length (2nd case) accordingly.
Volume = area * thickness
20K
