How Many Investment Strategies Exist for $20,000 Across 4 Opportunities?
  • Thread starter Thread starter e(ho0n3
    Counting
The discussion revolves around a combinatorial problem involving the distribution of a $20,000 investment across four opportunities, each with specified minimum investment requirements. The goal is to determine the number of different investment strategies while ensuring that at least three of the four opportunities receive funding.
  • Participants explore the combinations of opportunities and the implications of minimum investment requirements. Questions arise regarding the legality of certain investment amounts and the method for counting valid distributions. Some participants suggest a combinatorial approach to find nonnegative integer solutions to equations representing the remaining investment after minimums are met.
The discussion is active, with participants sharing their calculations and recognizing mistakes in their previous reasoning. There is a collaborative effort to clarify the counting method and explore the implications of different combinations of opportunities. While some calculations have been corrected, there remains uncertainty about the completeness of the approach.
Participants are working within the constraints of minimum investment amounts and the requirement to invest in at least three opportunities. There is an ongoing examination of how these constraints affect the total number of investment strategies.
e(ho0n3
[SOLVED] Funky Counting Question
Problem. We have 20 thousand dollars that must be invested among 4 possible opportunities. Each investment must be integral in units of 1 thousand dollars, and there are minimal investments that need to be made if one is to invest in these opportunities. The minimal investments are 2, 2, 3, and 4 thousand dollars. How many different investment strategies are available if investments must be made in at least 3 of the 4 opportunities.
Answers. 572
Attempt. Let a, b, c and d be the 4 possible opportunities with minimal investments of 2, 2, 3 and 4 thousand dollars respectively. The possible combinations of opportunities are abc, abd, acd and abcd right? Now, would it illegal to invest 3 thousand dollars into opportunity a? Must it be multiples of 2 thousand? Ditto for the rest of the opportunities.
If it has to be in multiples of the minimum investment, how would one count them effectively? All I can think of doing is writing down combinations and looking for patterns.
Hint: For each case... subtract away the minimum investment and see the numbers of ways to distribute the rest.
OK. I realize my mistake now. Also, there are more than 4 possible combinations of opportunities. The combinations are abc, abd, acd, bcd, abcd.
Consider abc. After investing the minimum, I'm left with 13 thousand to invest. Let A, B, C be the quantities in thousands that I must invest after the minimum investment in a, b, c respectively. All I have to do is find the number of nonnegative integer solutions to A + B + C = 13 right? That is C(13 + 3 - 1, 3 - 1) = C(15, 2) = 105. For abd, I get C(12 + 3 - 1, 3 - 1) = C(14, 2) = 91. For acd, I get C(11 + 3 - 1, 3 - 1) = C(13, 2) = 78. bcd is the same as acd so it should be 78. For abcd I get C(9 + 4 - 1, 4 - 1) = C(11, 3) = 165. I get 517 after adding them all up.
I'm still missing something. What could I be missing?
This should be (12,3) = 220
Ah! How embarrassing. Thanks.
no prob.
  • · Replies 46 ·
  • · Replies 28 ·
